Door cards
Door cards
Post by jonwood on Sat Nov 02, 2013 10:58 pm
Parking Holly half on the kerb to stop the roof light leaking on the drivers side but suspect that water has got onto my sliding door cards (she's a '98 MPV). The driver's sliding door card now drops out now when i open the door as the card had warped and the plastic plugs are knackered some what. Has anybody had any success making new door cards that can stand up to some wear?
Jon
jonwood
Re: Door cards
Post by Guest on Sun Nov 03, 2013 7:24 am
Two options John : Fix the leak or buy a couple of matching door cards and put a self adhesive plastic film on the hardboard and see if that stops the water soaking the back of the card.
If its the material that's getting soaked then back to plan A---- fix the leak or plan B ---- buy a load of door cards. Embarassed Very Happy .
Re: Door cards
Post by jonwood on Sat Nov 16, 2013 12:04 pm
Affirmative. I've got to fix the seal with the window for a start. Now I'm going to use the pattern of the old card to cut a new on and go with a film in the door and a poly-U spray to seal the material of the card too. Thanks Woody.
jonwood
Re: Door cards
