headlights.
headlights.
Post by bikerming on Sat Jun 26, 2010 5:20 pm
the bottom of both my headlights are missing the silver reflecting bit,is this normal?i have my mot coming up and i'm wondering wether to change them first.they don't seem rusty.any ideas?
bikerming
Re: headlights.
Post by kentgpz11 on Sat Jun 26, 2010 6:19 pm
One of ours is like this. Crying or Very sad
I was thinking of removing the glass to see if I can clean them up, if not I'll spray the inside with chrome effect spray. Smile
kentgpz11
Re: headlights.
Post by rich the mechanic on Mon Jun 28, 2010 9:18 pm
the chrome should be there for the light to have the correct beam pattern depending on how bad it is you may get away with it for MOT as for taking it apart if you can get the sealent out then you would be better to get it to a good chrome plater to strip polish and replate chrome effect paint might just bodge it but I would doubt it would cut the mustard for long with out removing the orginal problem corrosion doesn't just go away.
Re: headlights.
Post by Guest on Mon Jul 19, 2010 10:25 pm
Did anyone successfully clean their headlight units? I have one like that and MOT in two weeks!
headlights.
Post by bikerming on Tue Jul 20, 2010 1:01 am
i bought some better ones and it passed but i spoke to a mechanic and he said as long as the beam pattern shone as a v(small at the bottom,wide at the top)it would pass.
bikerming
Re: headlights.
Post by difflock123 on Tue Jul 20, 2010 10:13 am
tin foil will work for an MOT fix...
I have done it on a motorbike...
the reflector was very rusty, so opened the headlight, gave it a gentle sand with emery paper, and then glued some tin foil (shiny side out) and it worked fine...
Re: headlights.
Post by Guest on Tue Jul 20, 2010 11:42 am
Thanks Guys.. I will keep looking for new one but in the mean time will try your suggestions.. Cool
Re: headlights.
Post by Tukz on Thu Jul 22, 2010 12:34 am
Tukz
http://www.tuktuktravel.co.uk
Re: headlights.
Post by Guest on Thu Jul 22, 2010 8:34 am
I'm sure he's lovely.. Wink but they won't fit my 'S' reg 1999 model.. Crying or Very sad Thanks tho Very Happy
Sorted
Post by Guest on Mon Jul 26, 2010 8:29 pm
So after much cleaning effort and no success, I used this
http://www.amazon.co.uk/Rub-n-Buff-Silver-Leaf/dp/B00275X5HG
My friend is a master engraver and recommended it - It's dead simple to use just worked it into a cloth strip around my finger and then applied it as far as I could reach with my finger. For the bits I couldn't reach I bent a coat hanger wire into a long finger shape and made effectively a cloth cotton bud shape and finished it off. Allow to dry and repeat process with clean soft cloth to buff it up.
And the best bit? it sailed through the MOT this morning.. yay!!! Very Happy Very Happy Very Happy
I should also say that it was really badly tarninshed about 90 of it!
Last edited by The_Magic_Bus on Mon Jul 26, 2010 8:31 pm; edited 1 time in total (Reason for editing : To add a bit funnily enough :o))
Re: headlights.
Post by Guest on Mon Jul 26, 2010 8:33 pm
tarninshed ???????? Rolling Eyes Shocked Rolling Eyes methinks I could use the money saved for a dikshunary???? affraid
Re: headlights.
Post by difflock123 on Mon Jul 26, 2010 9:05 pm
or some soap Razz
I'm pretty sure thats a swear word in at least one language Razz Very Happy
Re: headlights.
Post by Guest on Mon Jul 26, 2010 9:29 pm
I bet it is actually.. What a Face Very Happy Very Happy Very Happy
Re: headlights.
Post by difflock123 on Tue Jul 27, 2010 11:26 am
I wonder if there is a "wash mouth out with soap" smiley? Razz
Might go on the hunt for one Smile
Re: headlights.
Post by Guest on Tue Jul 27, 2010 1:21 pm
Better make it a big bar lol!
Re: headlights.
Post by HighlyJetted on Wed Jul 28, 2010 4:26 am
difflock123 wrote:I have done it on a motorbike...
While moving?
That tape you get from B&Q near the sheets of kingspan insulation, basically sticky back alluminium foil works great too.
Another ghetto trick:- to get bonded glass headlights open shove them in the oven for 20 minutes at 80 degrees to soften the glue. Then prise open with credit cards. T-cut pollish and/or a hot air paint stripping gun can sometimes fix cloudy plastic headlight lenses depending on the plastic. And if you break rear ones you can cut squares out of a random red lense with a glowing stanley blade over a blow lamp... then fuse the perfect fitting patch into the broken one with a soldering iron.
Oh its like house wifes cleaning tips! Oh those cum stains are a pain.
Re: headlights.
Post by Guest on Wed Jul 28, 2010 9:29 am
Methinks that's two bars of soap now? Laughing Laughing
and also.. I didn't have any of "those" stains in my headlights affraid affraid *wonders*
Re: headlights.
Post by difflock123 on Wed Jul 28, 2010 12:35 pm
With a comment like that I dont want to know what you get up to Razz
And ghetto head light fix is a torch Razz
Re: headlights.
