fuel sender
Page 1 of 2 1, 2  Next
fuel sender
Post by rickatnewt on Fri Nov 22, 2013 5:04 pm
hi has enyone got a fuel sender unit for sale please mines cuputt lol it doesnt float lol
rickatnewt
Re: fuel sender
Post by melboy on Fri Nov 22, 2013 6:03 pm
hj or woody willsort you out.
melboy
Re: fuel sender
Post by HighlyJetted on Fri Nov 22, 2013 7:49 pm
I have non left, sold them all.
It is a stand pump though, but I don't think the motor factors know it.
Having a quick look, I think its the same as this one http://www.ebay.com.au/itm/GENUINE-DENSO-MITSUBISHI-FUEL-PUMP-LANCER-MAGNA-PAJERO-iO-TRITON-VERADA-EXPRESS-/251024890700
Re: fuel sender
Post by rickatnewt on Sat Nov 23, 2013 9:37 am
Thanks for info woody has got one but I am going to try and make the float lighter then if fit works out the unit will work I will post results
rickatnewt
Re: fuel sender
rickatnewt
Re: fuel sender
Post by HighlyJetted on Sat Nov 23, 2013 10:03 am
Sorry mis understood you.
I thought you ment fuel sender as in fuel pump
Not fuel sender as is fuel gauge pump
Anyway, I took a couple of non working ones apart yesterday as a local lad wants one. They stop working because:
Simple faults
The float has fallen out the end (will get no gauge or light)
The tube is kinked (level will stick on the gauge at some point)
Some of the wires at the top are broken
Less simple
The PCB tracks wear out where the float slides
The onboard resistors at the top brake off
Some one has cooked the resistors while messing with the wiring
Re: fuel sender
Post by HighlyJetted on Sat Nov 23, 2013 10:08 am
Also I can tell you that:-
Fuel Sender
Yellow/Green - Gauge wire
Blue - Fuel light wire
Black - Ground (tank)
Vans Wiring Loom
White/Black - Gauge wire
Re: fuel sender
Post by rickatnewt on Sat Nov 23, 2013 3:00 pm
Sad Thanks for link I can't get the float to float so a replacement it will have to be it's rather enjoying as the pcb works fine so if anyone needs the tube with the pcb in it contact me
rickatnewt
Re: fuel sender
Post by HighlyJetted on Sat Nov 23, 2013 4:53 pm
If you just want the float I have a few from the ones i've ripped up.
Re: fuel sender
Post by rickatnewt on Sat Nov 23, 2013 6:18 pm
Yes that would be great
rickatnewt
Re: fuel sender
Post by rickatnewt on Sat Nov 23, 2013 6:20 pm
If you could send to the horse and groom 40 Lynn street Swaffham Norfolk pe377ax I have paypal Acount thks
rickatnewt
Re: fuel sender
Post by HighlyJetted on Sat Nov 23, 2013 6:32 pm
Are you totally sure, that "I can't get the float to float"
I wonder how that has come about??
These definitely float in water, and will float even better in petrol!!
Re: fuel sender
Post by rickatnewt on Sat Nov 23, 2013 7:51 pm
Mine will float in water but not petrol I don't know why that is and it looks as if it's soaked up petrol ???
rickatnewt
Re: fuel sender
Post by HighlyJetted on Sat Nov 23, 2013 9:36 pm
I will try them in petrol as I always like an "interesting experiment"
Are you pulling my leg?
Re: fuel sender
Post by rickatnewt on Sat Nov 23, 2013 10:28 pm
No lmfao but it's very frustrating I thought I was going mad
rickatnewt
Re: fuel sender
Post by PFM on Sat Nov 23, 2013 10:36 pm
Hope you don't smoke, HJ!
Re: fuel sender
Post by HighlyJetted on Mon Nov 25, 2013 10:47 pm
I have now kept those two floats in petrol for the last 48 hours, and they continue to float!
So if you want one I'm happy to send one to you, for £2 for the float and £3 postage.
I take paypal at threepopt@hotmail.co.uk
Re: fuel sender
Post by rickatnewt on Mon Nov 25, 2013 11:54 pm
Sounds good to me you ain't far from me I can pick up if you want ??
rickatnewt
Re: fuel sender
Post by HighlyJetted on Tue Nov 26, 2013 12:11 am
Sure thing, I am in crewe, where are you?
Re: fuel sender
Post by PFM on Tue Nov 26, 2013 7:44 am
HJ, check that paypal addy - not sure it's quite right M8.
Re: fuel sender
Post by rickatnewt on Tue Nov 26, 2013 8:05 am
Opps thought you were closer sorry plz post ps I am in norfolk lol
rickatnewt
Re: fuel sender
Post by rickatnewt on Tue Nov 26, 2013 8:26 am
Money sent via PayPal thanks for your help awaiting float then I've nearly finished her
rickatnewt
Re: fuel sender
Post by HighlyJetted on Tue Nov 26, 2013 11:53 am
PFM wrote:HJ, check that paypal addy - not sure it's quite right M8.
Shit your right! Typing error Embarassed
You'll have to cancel the payment and send again to....
threepot@hotmail.co.uk
Re: fuel sender
Post by rickatnewt on Tue Nov 26, 2013 11:54 am
Ok will do
rickatnewt
Re: fuel sender
Post by rickatnewt on Wed Nov 27, 2013 2:15 pm
Thanks to hj the float arrived first post fitted it and low and behold it works fine thanks hj
rickatnewt
Re: fuel sender
Post by FrontBackSide2Side on Wed Nov 27, 2013 2:54 pm
Is the sender hard to get to? Ive got to have a look at mine but mines a pickup if that makes any difference.
Re: fuel sender
Post by rickatnewt on Wed Nov 27, 2013 3:15 pm
It's easy I thought 4bolts and a few pipes and it's off the whole tank then you can get to the sender easy ps mines a truck to
rickatnewt
Re: fuel sender
Post by FrontBackSide2Side on Wed Nov 27, 2013 3:50 pm
Thats good to hear, so you have to remove the whole tank? Thats not really a problem as ive got to replace mine (leaking).
Re: fuel sender
Post by HighlyJetted on Wed Nov 27, 2013 6:57 pm
pickup float tubes are about 3" smaller in length to van ones.
Re: fuel sender
