Fuel gauge
Fuel gauge
Post by FrontBackSide2Side on Mon Nov 25, 2013 11:16 am
I picked up my hijet yesterday and am overall really pleased with it Smile however there are a few niggles to sort, one of which is the fuel gauge doesn't work, it always shows empty. Would this be the sender unit? If so any idea where I can get one and is it a difficult job etc?
Re: Fuel gauge
Post by HighlyJetted on Mon Nov 25, 2013 11:41 am
Does the fuel light work?
Re: Fuel gauge
Post by FrontBackSide2Side on Mon Nov 25, 2013 11:54 am
I'm not sure, I'm a bit scared to let it get so low as I don't know how much fuel I have Sad
Re: Fuel gauge
Post by HighlyJetted on Mon Nov 25, 2013 12:20 pm
Keep a can full in the back, then run it till it starts cutting out.
Re: Fuel gauge
Post by FrontBackSide2Side on Mon Nov 25, 2013 12:23 pm
What if the light does/doesn't come on then? I might syphon the fuel out, save it cutting out in an inconvenient place.
Re: Fuel gauge
Post by FrontBackSide2Side on Thu Nov 28, 2013 11:07 am
Is this the sender unit I will need for my 2003 1.3 hijet pickup?
http://pages.ebay.com/link/?nav=item.view&id=360785636222
Re: Fuel gauge
Post by FrontBackSide2Side on Fri Nov 29, 2013 2:49 pm
anyone?
Re: Fuel gauge
Post by waz on Fri Nov 29, 2013 5:55 pm
I don't know FBS but but don't panic buy it as HJ or Woody may have one.
Re: Fuel gauge
Post by FrontBackSide2Side on Fri Nov 29, 2013 6:02 pm
Mine might be repairable yet but i wanted to find out just incase as im putting in an order with this ebay seller for some other parts and thought this seemed like a good price for a brand new OEM part Smile
Re: Fuel gauge
Post by 8bit-ash on Fri Nov 29, 2013 10:11 pm
That looks very much like what you need. You'll probably either find that the cable has corroded and snapped at the top of the sender or the float that slides up and down has fell out of the tube and is floating about in the tank.
Re: Fuel gauge
Post by FrontBackSide2Side on Fri Nov 29, 2013 10:27 pm
Cheers bud. I've got to change the fuel tank tomorrow so I'll be able to investigate then Smile
Re: Fuel gauge
Post by HighlyJetted on Sat Nov 30, 2013 1:25 am
That ebay fuel sender does look like the right one
Re: Fuel gauge
Post by FrontBackSide2Side on Sat Nov 30, 2013 7:29 am
Nice one, cheers mate.
Re: Fuel gauge
Post by FrontBackSide2Side on Sat Nov 30, 2013 5:07 pm
Had a look today whilst swapping the tank. The float was still inside the unit and appeared to be free enough. I repaired some corroded/broken wiring. The fuel light works now or at least it was on when I started the engine, the gauge is still on empty so I will put some fuel in later and see if it moves and hopefully the light will go out too. Fingers crossed! Smile
Re: Fuel gauge
Post by HighlyJetted on Sat Nov 30, 2013 7:05 pm
Well...... well.....
Does your gauge rise to the occasion?
Re: Fuel gauge
Post by FrontBackSide2Side on Sat Nov 30, 2013 10:14 pm
No.....and the fuel light is on constantly.....and the tank leaks.....epic fail lol
Re: Fuel gauge
Post by HighlyJetted on Sat Nov 30, 2013 10:45 pm
Re: Fuel gauge
Post by FrontBackSide2Side on Sat Nov 30, 2013 10:57 pm
Lol tell me about it! At least it leaks from the top of the tank now opposed to the seam (trying to look on the bright side here lol)
Re: Fuel gauge
Post by Logi on Sun Dec 01, 2013 8:53 am
Whats leaking? The sender seal?
Re: Fuel gauge
Post by FrontBackSide2Side on Sun Dec 01, 2013 8:55 am
It looks like it yeah.
Re: Fuel gauge
Post by Logi on Sun Dec 01, 2013 8:57 am
Well at least you know what you're doing now, practice etc..... Wink
Re: Fuel gauge
Post by FrontBackSide2Side on Sun Dec 01, 2013 9:02 am
lol yep thats one way to look at it. I've ordered that new sender off ebay now so i'll wait for that to turn up and just not fill the tank right the way up for now. Think i'll fill the tank with water before refitting it this time.
Re: Fuel gauge
Post by Logi on Sun Dec 01, 2013 9:07 am
Wouldn't fill it with water, you've just replaced a rusty tank. No point in starting the new one rusting already. Once you've done it six or seven times you'll can do it with your eyes shut..... Razz
Re: Fuel gauge
Post by FrontBackSide2Side on Sun Dec 01, 2013 9:27 am
very true, but don't they rot from the outside? The old one looked brand new inside Smile
Re: Fuel gauge
