Thermostat top hose blowing off. 1.3
Post by 8bit-ash on Fri Jul 09, 2010 6:23 pm
Has this happened to anyone? Twice in a week now the top hose on the thermostat flange has blown off when hot causing the van to overheat. Temp guage is fine then all of a sudden it raises and I can smell coolant. Look under the seat and hey presto hose is off and coolant is everywhere.
Re: Thermostat top hose blowing off. 1.3
Post by rich the mechanic on Fri Jul 09, 2010 6:42 pm
its either a head gasket faliure and pressure build up or is the crap clips mine are beeing replaced by proper jubilee clips
Post by 8bit-ash on Fri Jul 09, 2010 7:02 pm
lets hope its crap clips although they seem pretty good. Van runs spot on then it just randomly happens.
Post by leopard_pagan on Sat Jul 10, 2010 9:05 am
give the system a good clean out while your at it..
2 denture tablets work a treat, dissolve em in a bit of water 1st.
new hose clamps + check if there is still a wee lip on the housing neck bit.
