blower question?
blower question?
Post by simmo116 on Mon Dec 02, 2013 9:34 pm
Hi gang noticed today that my heater blower only works on the last setting, is this a common problem or sign of something more serious? not got round to sorting the under seat rad cap ordered new one fitted it but still passing plan to clean all the corrosion off and build it back up with gasket sealer. fingers crossed.
simmo116
Re: blower question?
Post by Logi on Mon Dec 02, 2013 9:41 pm
Heater blowers are a common problem, I need to wiggle mine to get it fast..... affraid
Post by simmo116 on Mon Dec 02, 2013 10:06 pm
only fast works on mine. I do notice that there is a slight warm breeze on the windscreen when turned off
simmo116
Post by Mini-deli on Tue Dec 03, 2013 11:06 am
Recently done mine. The thing stopped completely.
I found that the tracks on the slider control were in a bad state and a soldered wire had 'dry-jointed'.
I just took it apart and cleaned everything up - and wet-jointed the connection.
Job's a gud'un.......Razz
Mini-deli
Post by PFM on Tue Dec 03, 2013 2:35 pm
That's interesting. Mine hasn't worked on slowest setting for some time and I presumed it was the rheostat but, as that's a pain to get to, I just put up with it. Maybe I'll have a look at the slider then.
Post by Guest on Tue Dec 03, 2013 11:15 pm
Hhhmm! Must admit I would have guessed at the rheostat. Got a few heater units out so will have a look see tomorrow at the slider control.
Post by HighlyJetted on Tue Dec 03, 2013 11:39 pm
A few people have mentioned dodgy switches, just the contacts from memory.
Post by Guest on Tue Dec 03, 2013 11:49 pm
Logi wrote: I need to wiggle mine to get it fast..... affraid
Definitely no comment there Logi !!!    I cant imagine what you mean Embarassed Embarassed
