Rea Shock Bushes
Rea Shock Bushes
Post by Logi on Sun Dec 08, 2013 10:28 pm
My last van needed one, pretty sure others have mentioned it here. I generally use insulating tape to make up the slack Wink but was looking for bushes for the Jag droplinks and came across these whilst noseying around.
http://www.superflex.co.uk/products.php?cat=393
Not sure of the Hijet sizes tho?
Re: Rea Shock Bushes
Post by FrontBackSide2Side on Mon Dec 09, 2013 10:00 pm
Nice find, it would be good if we could compile a list of compatible bushes between us all Smile
Post by HighlyJetted on Mon Dec 09, 2013 10:37 pm
If your totally stuck for bushes, I've made them out of a tube of:-
http://www.ebay.co.uk/itm/U-POL-TIGER-SEAL-PU-ADHESIVE-SEALANT-TIGERSEAL-BLACK-/291014306990?pt=UK_Body_Shop_Supplies_Paint&hash=item43c1cdecae
They just take about a 5 days to cure!! Even in the airing cupboard.
Post by rich the mechanic on Wed Dec 11, 2013 8:38 pm
Supaflex used to be cheap and good but now they are the same as duflex and the others, however it is only polyurathane which is the stuff they use as press stripper you can buy a 12" length with a 17mm hole and using a sharp tool turn your onw up in a lathe. The whole back end of my Escort is poly or sherical bearing bushed all made at home, I bought the front kit and then supaflex got into financial trouble and I couldn't get the rest and couldn't afford the price from the others.
