Side steps
Side steps
Post by dee26173 on Wed Jul 14, 2010 8:03 am
Does anyone know where I can get some side steps for my 1.3 mpv?
dee26173
Re: Side steps
Post by rich the mechanic on Wed Jul 14, 2010 9:57 pm
no but make a bracket and fit landrover ones Cool or similar 4x4 jobbies
Re: Side steps
Post by difflock123 on Thu Jul 15, 2010 8:24 am
If you choose the right side steps (Land Rover ones) you can have little fold down steps Smile
I dont know where it would be possible to mount side steps etc as I havent looked under the sides with them in mind...
if you can work out where to mount them, you can cheaply and easily make a set of side runners...
all you need is to get some strong angle iron, and a couple of pieces of small box section.
the angle iron runs under and is bolted to the van, 1 at the front, 1 at the rear (each side) and then the box section (1" square would do) is put between the angle iron.
you could fit 2 lengths of box section and then cut a sheet of chequer plate and rivet that on if you wanted...
as for fixing the box section to the angle iron, you can either bolt it together or if you (or someone you know) has a welder they can be welded together...
Quite cheap if you can do the bit of working out....
Re: Side steps
