Coolant levels
Coolant levels
Post by Willst0ne on Thu Dec 12, 2013 11:43 am
So I topped up the coolant in the reserve tank - but this seems to have had no affect on the level of the coolant under the metal cap? Your help appriciated. W
Willst0ne
Re: Coolant levels
Post by elfin girl on Thu Dec 12, 2013 5:54 pm
top up from under the metal cap :-)
Re: Coolant levels
Post by Logi on Thu Dec 12, 2013 6:41 pm
daisydon wrote:top up from under the metal cap :-)
^^^^^^^^^^ This Smile
Re: Coolant levels
Post by Willst0ne on Thu Dec 12, 2013 9:30 pm
Gggggreat thanks. I'll be trying that tomorrow. Last question then.....
As the coolant is a bit "milky" could anyone give me a good step by step to do a complete coolant change and flush?
Many thanks
Willst0ne
Re: Coolant levels
Post by elfin girl on Thu Dec 12, 2013 11:41 pm
hj has a break down on here somewhere, if you search for coolant or other words associated you should find it, milky coolant doesnt sound good btw hopefully itll be fine :-\
Re: Coolant levels
Post by Logi on Fri Dec 13, 2013 6:01 am
daisydon wrote:hj has a break down on here somewhere :-\
He does get a bit agitated but I don't rreckon you should call it a breakdown....  lol!
Re: Coolant levels
Post by Willst0ne on Fri Dec 13, 2013 7:05 am
daisydon wrote:hj has a break down on here somewhere, if you search for coolant or other words associated you should find it, milky coolant doesnt sound good btw hopefully itll be fine :-\
That's because I topped it up with semi skimmed. Should I have used full fat? I've had a search for changing the coolant but all I've found are topping it up posts. Any pointers as to where the step by step guide is hiding?
Willst0ne
Re: Coolant levels
Post by elfin girl on Fri Dec 13, 2013 10:45 am
theres a vid posted on here, hj showing how he does it  Wink
http://hijet.findtalk.biz/t2036-and-so-it-begins#18760
Re: Coolant levels
Post by elfin girl on Fri Dec 13, 2013 10:48 am
this method can be used to top up or refill after emptying and flushing out
Re: Coolant levels
