Couple of questions
Couple of questions
Post by FrontBackSide2Side on Tue Dec 17, 2013 7:39 pm
Is there supposed to be an adjuster on the alternator for tensioning the belt? I changed the belt earlier and had to lever the alternator into position and tighten the bolts up, is this normal?
Also whilst doing the job I noticed this contraption with a pipe going into the airbox. What is it? Is it something to do with the noe defunct LPG system?
Re: Couple of questions
Post by HighlyJetted on Tue Dec 17, 2013 8:53 pm
Yep, thats the LPG vaporiser.
And yes, the belt tensioner works as simple as that.
Post by FrontBackSide2Side on Tue Dec 17, 2013 9:15 pm
Thanks for the reply. So im guessing i can remove the vapouriser without any issues? obviously i would have to remove the coolant lines.
