993 EFI Temprature sender location. with pics!
Post by leopard_pagan on Fri Jul 16, 2010 4:57 pm
want to check/test the temp gauge and sender unit. but i gotta find the bugger first!
anyone know where it lives on a EFI 993 hijet?
i am told it "should" be near the thermostat.. but i dont remember seeing it.
i am also going to re-flush the coolant system with rust remover and circulate it for longer than last time.
Re: 993 EFI Temprature sender location. with pics!
Post by rich the mechanic on Sat Jul 17, 2010 10:01 pm
take the rear cowl off and then look up from underneath it is just below the stst housing I know coz I forgot to reconect m ine after I did the head the first time.
Post by leopard_pagan on Fri Aug 06, 2010 12:43 pm
is it "plugged" in to the exhaust just before the Catalytic converter?
Post by leopard_pagan on Fri Aug 06, 2010 1:10 pm
This is the part i was given by car shop.... if its the green plug in the pic, the sods sold me the wrong part!. the one in the exhaust pipe is too big to be this.. + i think that is a EFI sensor?.. not what i am after.
Green plug? under stat...
view from under passenger side of van.. green plug is hiden by the metal pipe
2nd view from under van,
Post by rich the mechanic on Fri Aug 06, 2010 8:24 pm
yes its the green plug just under the stat housing
Post by leopard_pagan on Sat Aug 07, 2010 8:10 am
cheers.... feckers sold me the wrong thing. will sort that out this arvo. Suspect
