1300 camshaft
1300 camshaft
Post by davidc on Tue Dec 31, 2013 2:54 pm
has any one got a 1300 camshaft as the lobes on mine have completley worn away thank you
davidc
Re: 1300 camshaft
Post by HighlyJetted on Tue Dec 31, 2013 4:11 pm
What are the journals like on it?
If its been that dry that the lobes have worn, you will have more problems realistically.
I do have a complete cylinder head ready to go on the shelf for just £85 plus I can post it for about £8 - which has cams lifters valves the lot.
Re: 1300 camshaft
Post by davidc on Tue Dec 31, 2013 7:09 pm
the journals are in really good condition hardly any wear i was thinking is was down to a bad cast cam when made i had one go like this on another car
davidc
Re: 1300 camshaft
Post by HighlyJetted on Tue Dec 31, 2013 7:31 pm
I personally won't split a cam from a head, they go as a complete top end.
What about the rockers/lifters - if the cam has worn so much the faces of the rockers/lifter must have taken some of the pain.
Re: 1300 camshaft
Post by Guest on Sat Jan 11, 2014 10:27 pm
I have a cam if you are still looking for one and the set of matching followers which I will number up so they end up with the original followers on the right lobes. Woody. 07970 391876.
Re: 1300 camshaft
