woweeee teeny tiny engine
Post by elfin girl on Thu Jan 02, 2014 3:51 pm
now i wish i could make stuff like this
http://welldonestuff.com/worlds-smallest-v-12-engine/
Re: woweeee teeny tiny engine
Post by HighlyJetted on Thu Jan 02, 2014 5:30 pm
Yep working model engine building is quite a popular hobby.
Some serious skilled work goes into them.
Post by rich the mechanic on Thu Jan 02, 2014 9:09 pm
You could if you had the time to spend doing it.
Post by HighlyJetted on Thu Jan 02, 2014 11:55 pm
Precision engineering isn't cheap either.
Post by rich the mechanic on Fri Jan 03, 2014 8:11 pm
It's not expensive unless your charging by the hour it's just very time consuming.
Post by nc30 on Fri Jan 03, 2014 9:13 pm
There's a great one here:
V8 EFI model engine
Have a look through the forum posts, it's an awesome build log. The link is for page 34 where the engine finally runs!
Wish I had a milling machine, lathe, and... skills.
nc30
Post by HighlyJetted on Fri Jan 03, 2014 9:24 pm
rich the mechanic wrote:It's not expensive unless your charging by the hour it's just very time consuming.
nc30 wrote:Wish I had a milling machine, lathe, and... skills.
This is the cost... measuring gear, machining and turning gear, materials, cutting tips, and some serious attention to design and engineering.
You would have to burn a couple of grand on tooling just to get going. But a good investment I would say!  Smile
I could retire playing with stuff like that as a little old man.
