Starting hijet after downpour
Post by dee26173 on Wed Jul 21, 2010 11:39 am
I went to start my hijet yesterday to drop it off at a mates and it wouldn't start. All the symbol lights on the console lit up which suggested it wasn't the battery. Turned it over again and it started. My mate has now said it won't start again. It's been bucketing down for 2 days now and I just wonder if anyone has had similar problems? confused
dee26173
Re: Starting hijet after downpour
Post by difflock123 on Wed Jul 21, 2010 2:43 pm
mine the other day (hadnt been started for a week) and then the last 2 days it rained badly.
I started it, but after a few seconds the engine stalled...started it again and gave the throttle a good blip and all was fine...
Only think I can think is no fuel in the fuel lines...
perhaps the fuel pump isnt working :S
turn it over for a few seconds, wait, and then try again...
might be worth having the throttle on 1/4...
good luck
if it isnt that, make sure it has a good spark...
how old are the spark plugs?
Post by dee26173 on Wed Jul 21, 2010 6:19 pm
I have no idea in relation to the Spark Plugs. A friend is taking it on Saturday for other work to be carried out so hopefully I can get it started to get to his. Many thanks for the advice, I appreciate it cheers Dee
dee26173
Post by HighlyJetted on Sat Jul 24, 2010 3:23 pm
Ignition systems on these are crap when damp.
Check the dizzy cap, rotor arm, plugs and leads.
Often start then run abit lumpy for a 10 seconds then start firing on all 4.
Post by difflock123 on Sat Jul 24, 2010 5:35 pm
unless its a 3 cylinder Razz
Then it just runs lumpy all the time Wink
Sound good though Razz
Post by leopard_pagan on Sun Jul 25, 2010 8:36 am
i need to start mine up, not been used for over 2 weeks!
Post by dee26173 on Sun Jul 25, 2010 1:34 pm
It was a duff battery after all. £63 for a new one!!!!!
dee26173
Post by HighlyJetted on Mon Jul 26, 2010 2:20 pm
difflock123 wrote:unless its a 3 cylinder Razz
Theres always one! I love threepots, especially charade GTti's and the Toyota Igo aint bad. Something about a 3 banger at 7,000 rpm. Triumph speed tripples growl nice too.
Back on topic... don't be supprised if the knackard battery just showed the symptoms of other faults, how many customers have had 3 new batteries in 2 years then realise a weak alternator was the cause. When the ignition voltage is down they don't spark blue and crisp the way they should, plus it can make the coil/ignitior respond slower making the spark timing late.
Post by difflock123 on Mon Jul 26, 2010 5:42 pm
I love my hijet because its the 3 cylinder...
when empty its got a surprising amount of go if you rev it...
I do wonder if its a 2 stroke though...
you pull away and its slowly accelerating, and then you get the revs over probably 4~5k rpm and it takes off Smile
Mind you, mine will hit the rev limiter in 3rd Razz (60mph... Very Happy)
Post by HighlyJetted on Wed Jul 28, 2010 3:38 am
Mines the 1.3 and its not under powered in the slightest. If you grow hijet balls of steel you'd be suprised what you can keep up with but keep it real smooth, and forget about the whole crumple zone thing. Unless the tarmac is dry i'd say my hijet has far more power than traction. And to most people disbelief I can't say i've ever felt like it was going to roll over, maybe blown over on the motorway! Although they do wash out on you when the back end gets past about 30 degrees in the wet. Mine goes about 1st 20, 2nd 40, 3rd 63/5, 4th 85/7, 5th 1??ph !! I have never had the balls to hang on till it stops pulling.
Post by difflock123 on Wed Jul 28, 2010 12:51 pm
Mine will hit 78mph with 2 people in it Smile
I havent really got much fear so I send it sideways too much Razz
