M.O.T PASSED
M.O.T PASSED
Post by GEORDIE on Fri Jan 17, 2014 1:09 am
Well the old van passed but not without some Pre work
front brake calipers stripped pins and sliders buffed up 9a battle)
new pads front brake pipe changed (another battle) rears cleaned,4 tyres
only needed 2 but what the hell,door hinge changed (thanks HJ)
so now another year becons
advisory---slight rust on underside
I wonder what they expect on a 1993 van!!
                                Geordie
GEORDIE
Re: M.O.T PASSED
Post by HighlyJetted on Fri Jan 17, 2014 1:45 am
Y'know, there is a clever little trick to getting them caliper pins out Wink
But it's too late now Sad
Re: M.O.T PASSED
Post by GEORDIE on Fri Jan 17, 2014 1:49 am
HJ tried the hydraulic trick,had to use heat
mole grips and brute force to win the buggers
GEORDIE
Re: M.O.T PASSED
Post by Logi on Fri Jan 17, 2014 6:07 am
Well done Smile
Re: M.O.T PASSED
Post by HighlyJetted on Fri Jan 17, 2014 8:52 am
GEORDIE wrote:HJ tried the hydraulic trick,had to use heat
I use the hydraulic power of the brake pedal, but with the engine running so you've got the brake booster helping, and literally stand on the brake pedal.
Then I hit on the calliper housing with a hammer and the shock plus the applied pressure makes them let go.
Well done on the MOT!!
Re: M.O.T PASSED
Post by Logi on Fri Jan 17, 2014 9:07 am
Must say i find the calipers on the Jet shittyer than most for seizing, spent a good bit of time stripping and cleaning mine, tho.as my van has lived by the seaside this may explain it?
I made a wee tool out of a brake banjo bopt and a metal tyre valve, brill thing for removing stuck pistons( admittedly a wee bitty dangerous when they pop,always cover with a cloth) but makes life much easier( no help wi the pins tho)
Re: M.O.T PASSED
Post by GEORDIE on Fri Jan 17, 2014 12:02 pm
Thanks Logie,one of the pins had to be cut off
and the drilled out!.Cleaning the sliders I put
a long bolt through them clamp whats left of
the bolt into the pedestal drill spin her up
and use fine emery makes a good job of them
GEORDIE
Re: M.O.T PASSED
Post by P165TER on Fri Jan 17, 2014 5:42 pm
My mate showed me avery easy way to get the pins out, after I had snapped off all but half inch of the pin.
DON'T clamp the caliper in a vice and get a pair of mole grips or similar on the pin.
Clamp the pin in the vice and gently rock the caliper.
It worked instantly
P165TER
Re: M.O.T PASSED
Post by xxemaphorr on Mon Jan 20, 2014 4:51 pm
Nearly enough of us to have a Lincolnshire hijet owners club now!
xxemaphorr
Re: M.O.T PASSED
Post by GEORDIE on Mon Jan 20, 2014 4:55 pm
True,use mine as a moble radio shack,so if you
see a white one running around town with a
strange roofbar its me!!
GEORDIE
Re: M.O.T PASSED
Post by xxemaphorr on Mon Jan 20, 2014 5:01 pm
I'll keep an eye out! congrats on the mot
xxemaphorr
Re: M.O.T PASSED
Post by P165TER on Mon Jan 20, 2014 9:12 pm
Our own little gang  Smile
P165TER
Re: M.O.T PASSED
