1.3 efi LPG Won't Start
Post by 8bit-ash on Fri Jul 23, 2010 8:09 pm
The Hijet has been getting progressively harder to start from Cold. Now it won't start at all. Just turns over. There is spark and petrol. I always start from cold on petrol but it won't start on either. Is there any common places to start?
Cheers
Re: 1.3 efi LPG Won't Start
Post by leopard_pagan on Fri Jul 23, 2010 8:43 pm
Check the battery, change the plugs, then HT leads, then the rotor.
Post by 8bit-ash on Fri Jul 23, 2010 9:01 pm
Batteries fully charged and it turns over fine. Checked plugs and they seem fine and spark. I may change them anyhow to be sure, It started fine once warm (when it did start from cold). Seems strange how its progressively got harder to start over about a month.
Post by leopard_pagan on Sat Jul 24, 2010 9:13 am
HT leads. they do break down in time. i got a set from local car shop for reasonable money
Post by difflock123 on Sat Jul 24, 2010 1:40 pm
Just because you get a spark at the plug when you tested that, doesnt mean that its enough to start and run...
change the plugs, the ht leads and the rotor and then go from there...
And make sure the plug gap is correct...
The fact that its been getting worse over a period of time points to something wearing out...
Post by Tukz on Sat Jul 24, 2010 5:43 pm
I can't remember what it is called but there is a little ceramic box thingy near the coil in a cage thingy, That on mine had a crack in it and although we couldn't see it until it got alot worse it did have exactly the same starting problem as yours. I replaced that and never had any problems since!.
Tukz
http://www.tuktuktravel.co.uk
Post by difflock123 on Sat Jul 24, 2010 8:37 pm
That sounds like an HT Lead suppressor to stop interference...
Post by 8bit-ash on Wed Jul 28, 2010 5:19 pm
Had some spare time yesterday so had all the plugs out. On testing 2 were dead, 1 was way out on resistance and the other was OK. Quick trip to Eurocarparts, £4 later and it starts like a dream. Will prob change the Leads too as resistance values are a bit off but can't find anyone non Gen that supplies them and I hate to think what Daihatsu will want for them when a little exhaust gasket is £15.
