98 660cc hijet truck wont start
Post by kreder on Tue Jan 21, 2014 12:16 am
It will start once in a blue moon and it will run great for the rest of the day, but once it sits over night good luck getting her to start in the morning... any ideas?
kreder
Re: 98 660cc hijet truck wont start
Post by kreder on Tue Jan 21, 2014 2:30 am
I have checked the spark and rebuilt the carb and still no luck
kreder
Post by HighlyJetted on Tue Jan 21, 2014 2:40 am
You need to spark test it.
Use a timing light!
Post by bushwhacker on Tue Jan 21, 2014 2:30 pm
Battery?
Post by kreder on Wed Jan 22, 2014 12:12 am
battery is new. and if it was out of time wouldn't it run rough all the time?
kreder
Post by PFM on Wed Jan 22, 2014 8:09 am
Don't know what the set-up is on that but I have a dim recollection of a tiny air-leak on the fuel line to the carb causing similar problems on a car - but memory going back 30+ years here.
Post by HighlyJetted on Wed Jan 22, 2014 9:56 am
kreder wrote:battery is new. and if it was out of time wouldn't it run rough all the time?
kreder wrote:I have checked the spark and rebuilt the carb and still no luck
 Shocked
Post by kreder on Thu Jan 23, 2014 1:48 am
if it take the carb off, put gas on a rag stick it over the intake should it fire or atleast putter<? I have done that and all it dose is change the pitch of the engine
kreder
Post by HighlyJetted on Thu Jan 23, 2014 10:57 am
That depend on if your ignition system is working.
As per my initial post, check your ignition system with a timing light (crude) or an oscilloscope using a current inducer clamp probe.
Although a rag might not work as it may not release enough fuel, I use a squirty bottle with fuel in it set to a fine spray.
Post by FrontBackSide2Side on Thu Jan 23, 2014 2:40 pm
or just use a can of deodourant Wink
Post by kreder on Tue Jan 28, 2014 12:23 am
well I replaced all the fuel lines, vac hoses, checked spark, new pugs, its still a bugger to get started but once It starts it runs great and will run on and off all day long but as soon as it sits for 5 hours or more it doesn't want to start, it also seems like I burning a lot of oil?? Neutral
kreder
Post by HighlyJetted on Tue Jan 28, 2014 12:42 am
Valve stem oil seals could me toasted. But I'm not sure this would cause your starting problem.
