power steering
power steering
Post by sterlingmc on Wed Jan 22, 2014 7:38 am
Hi
I have a open back Suzuki Carry, and the eps light has come on.Can i still drive the van and can anybody tell me if it is a expensive job?
sterlingmc
Re: power steering
Post by HighlyJetted on Wed Jan 22, 2014 9:55 am
Thats a bit like asking how long is a piece of string that is in my pocket.
I can tell you that its quite a simple electronic system.
And with some experience targeted diagnostics it will be easily solved.
Re: power steering
Post by sterlingmc on Wed Jan 22, 2014 10:58 am
ok. so it is electronic and would anybody know where to locate the eps
sterlingmc
Re: power steering
Post by HighlyJetted on Wed Jan 22, 2014 7:44 pm
On your average EPS system there is:-
A motor on the steering rack.
A sensor on the rack
A sensor on the steering column
Some form of EPS ecu stashed somewhere
The EPS ecu is connected to a pin on your OBD2 port so the error codes can be reset and retrieved using a specialist scanner - not a common cheap OBD2 scanner though.
Read this, although it is for the suzuki swift, it will be roughly the same setup most likely:- http://www.suzukiswift.sk/downloads/6-swift-vol2-steering.pdf
Re: power steering
Post by GEORDIE on Thu Jan 23, 2014 12:21 am
I had that problem on the wifes Agilia,
turned out the battery was duff,with
the old battery the light stayed on for
about 10 minutes before it went out
GEORDIE
Re: power steering
Post by sterlingmc on Thu Jan 23, 2014 7:41 am
thank you for the fantastic replies, so helpful when you are out of your depth, and even if i decide not to under take the work, i have knowledge to take with me to the garage.
sterlingmc
Re: power steering
