changing spark plugs on a 1.3
Post by leopard_pagan on Sat Jan 25, 2014 10:38 am
this might sound like a total thick question....
how many plugs does a 1.3 petrol (not LPG) have?
i can only see 2 HT leads under the passenger seat....
what looks like the coil packs bolted to the rear 2 slots where i'd expect to see HT leads to.....
does one change the front 2 as "normal" then unbolt the coil packs from the head from the rear hump access?
Re: changing spark plugs on a 1.3
Post by HighlyJetted on Sat Jan 25, 2014 11:12 am
Yep, other two plugs under the coil packs, undo the 10mm nuts and out comes the whole coil pack and rubber tube that goes to the plug underneath.
Post by leopard_pagan on Sat Jan 25, 2014 11:57 am
sorted Very Happy
i did phone our Woody as i was in the middle of doing them.
Hope your better soon mate.
Nowt untoward with the spark plugs.. see if changing them will change the fuel consumption..... bloody needs to!
Post by Guest on Sat Jan 25, 2014 5:12 pm
Thank you LP. Nothing that a cyanide pill or a bullet would sort.  Smile  Smile
