Positive battery cable replacement for 1991 Hijet 2 wheel drive 3 cylinder truck
Post by Guest on Sun Jan 26, 2014 5:40 pm
I need to replace the positive battery cable on my truck. Is this a specialised piece or are these cables generic?
Re: Positive battery cable replacement for 1991 Hijet 2 wheel drive 3 cylinder truck
Post by rich the mechanic on Sun Jan 26, 2014 5:52 pm
The OE stuff will be more than the truck is worth well at least over here anyway. However if it is the junction thaty has failed it can be repaired without having to replace the whole thing. Someone who has done it will tell you how.
Post by Logi on Sun Jan 26, 2014 6:26 pm
Why do you need to replace the battery cable?
battery cable
Post by Guest on Sun Jan 26, 2014 7:34 pm
Logi wrote:Why do you need to replace the battery cable?
Because the truck will not start, the battery is good, so is the alternator, sometimes truck starts, sometimes doesn't. I asked on this site and the battery cable was suggested as the possible issue. I wonder if it might be the solenoid?
Post by Logi on Sun Jan 26, 2014 7:39 pm
It's not the big cable that's the fault usually, there are 2 little cables attached to the positive, about 10 inches from the terminal(on a van anyway) there is a wee connector. It's shit. The wires corrode and cause all the electrics to go out.
Strip these back a foot or so and re-connect good wire to the battery, 95% sure therein lies your problem Smile
Post by Guest on Sun Jan 26, 2014 7:52 pm
Thank you so much for this answer, I really appreciate it.
Post by Guest on Mon Jan 27, 2014 12:29 am
Problem fixed. Thank you so much for your help !!!  Laughing
Post by Guest on Mon Jan 27, 2014 1:51 pm
How do I  post a picture?  I tried to insert image and host image, neither works.  I want to use a picture stored on my computer, not a URL.  Thanks in advance
Post by Logi on Mon Jan 27, 2014 4:42 pm
Click "host image", pick the pic Wink, click "host it", wait............................ "allow access?" Yes. Copy the MIDDLE url, paste it in.
Post by waz on Mon Jan 27, 2014 5:08 pm
Logi wrote:Click "host image", pick the pic Wink, click "host it", wait............................ "allow access?" Yes. Copy the MIDDLE url, paste it in.
Yea right, I waited ans waited and came up with an empty page.
Post by Logi on Mon Jan 27, 2014 5:13 pm
Works for me, here's some pussy  Laughing
Post by waz on Mon Jan 27, 2014 7:02 pm
Logi Do you have to register to use the host photos? When I click host it I don't get 'allow', it goes to the 3 choices then when I pick the middle one it just goes back to host photo
edit to add 3 choices
Post by PFM on Mon Jan 27, 2014 7:14 pm
Careful, Logi - Anne's Shye
Post by HighlyJetted on Mon Jan 27, 2014 8:06 pm
This is all very funny typical Hijet stuff.
That cable fault, plus then wanting new parts (!), then failing to post photos.
WELCOME TO THE FORUM!!! Smile
Post by P165TER on Mon Jan 27, 2014 9:51 pm
Logi wrote:It's not the big cable that's the fault usually, there are 2 little cables attached to the positive, about 10 inches from the terminal(on a van anyway) there is a wee connector. It's shit. The wires corrode and cause all the electrics to go out.
This is exactly what happend to my van. The bloody mechanic didn't put the strap that holds the battery in, back in after swapping the battery for a new one. A few speed bumps later and guess what? The battery had jumped around and cut through both of those little wires. Luckyly a friend came and rescued me. Had a quick poke round with his multimeter and worked out what was wrong.
P165TER
Post by Guest on Mon Jan 27, 2014 10:25 pm
Thank you everyone for chiming in with your comments and help.  I appreciate it .
Post by waz on Mon Jan 27, 2014 11:59 pm
Here's a golf photo
