exhijet now suzuki carry project
Page 5 of 10 Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Re: exhijet now suzuki carry project
Post by Eightpot on Wed Nov 19, 2014 4:34 pm
The thermostat should come with a grooved rubber o-ring which seals the housing to the block and holds the thermostat in place. At least my replacement did.
Eightpot
Post by scotia on Wed Nov 19, 2014 4:44 pm
scotia wrote:opened it up..
reason for overheating number one
i fitted the thermostat wrong Embarassed
the litle pin was at the wrong position.
number 2-- thermostat housing leaked.
doesnt there need to be a gaskett or something between the housing and the engine?
there was nothing there...plastic on metal.
Eightpot wrote:The thermostat should come with a grooved rubber o-ring which seals the housing to the block and holds the thermostat in place. At least my replacement did.
yes it did,are you talking about this ring?
but i meant the plastic thermostathousing.
does there need to be a gaskett or something between the housing and the engine?
like on this picture
i did a pressure test without the thermostat but with the housing on and it leaked on several points between the housing and the engine.
and another question.. on my altenator theres a sticker that says S12 i thought i saw a picture here somewhere
from somebody else and that had a sticker with a different number.
i cant seem to find that picture again but i was sure it didnt say S12 like mine..
Post by HighlyJetted on Wed Nov 19, 2014 6:33 pm
There is no flange gasket, the seal is the rubber on the thermostat itself.
Post by HighlyJetted on Wed Nov 19, 2014 6:40 pm
But I use some RTV silicon sealant when I put them on, and I let it cure for an hour or two before I put coolant in there.
I also clean up the faces as good as possible.
Post by HighlyJetted on Wed Nov 19, 2014 6:46 pm
scotia wrote:so youre telling me i should buy the cheapest one i can get?
its not that i dont believe you but i think thats realy funny because i thought i should buy
the gates one because it was kind of expensive for a thermostat and a well known brand Neutral Evil or Very Mad
http://www.mijnautoonderdelen.nl/daihatsu/hijet/65971/65977/thermostaat
Looking at that, it would seem that I am telling you to buy the cheapest one on the list!!!
Here in the UK, I can get a circoli one or other no-name thermostat for about £4 - but they are rubbish.
I love the nipparts ones, because they have not caused me any problems - yet! And they are half the price of a blueprint thermostat.
What I can say, is I think Gates Hijet fan belts are rubbish, the V profile and notches on the belt don't grip the pulleys very well.
Post by scotia on Thu Nov 20, 2014 7:03 am
ok, thanx for the info Smile
Post by bushwhacker on Thu Nov 20, 2014 5:04 pm
scotia wrote:
...... and another question.. on my altenator theres a sticker that says S12 i thought i saw a picture here somewhere
I put a link to a picture, which I think showed the alternator, under 'air filter query' in the Workshop section. I seem to remember it was labelled S12 but I can't check as the computer I am using is blocking pictures
Post by scotia on Fri Nov 21, 2014 7:42 am
aah yes i think that was the picture
thanx
i was wrong and didnt remember correctly, it also says s12
Post by bushwhacker on Sat Nov 22, 2014 5:06 pm
HighlyJetted wrote:
.......What I can say, is I think Gates Hijet fan belts are rubbish, the V profile and notches on the belt don't grip the pulleys very well.
That's probably about right.
I had a fan belt fail once which was replaced by a garage. The replacement then failed. Turned out it was a Gates one.
That was replaced by a Halfords one which, as far as I know , is still on the vehicle.
Presumably Gates is the type supplied through the motor factors that garages use.
Post by HighlyJetted on Sat Nov 22, 2014 10:56 pm
Eurocarparts try to sell them to me. I am not so keen!
Post by oldie on Sun Nov 23, 2014 6:25 am
Be very wary of Eurocarparts, you think your buying a 'brand-name' quality product....but you'll often find a lesser quality and cheaper 'pattern-part' when you open the packaging......but you still pay for the 'brand-named' quality product.
Post by Logi on Sun Nov 23, 2014 7:33 am
Hmm, Eurofakeparts, knock off shite that's taking over the motorfactoring business Sad
Post by scotia on Thu Nov 27, 2014 8:15 am
HighlyJetted wrote:
Out of all the crazy cars I driven over the years, this on is my favourite so far!
does your friend still have it?
i found a nice new engine maybe something for him..?
http://www.marktplaats.nl/a/auto-onderdelen/daihatsu-onderdelen/m841463711-nieuwe-daihatsu-jb-det-660cc-efi-turbo-motor-motorblok.html?c=be2da871b0d84f75c3056cc6db858f31&previousPage=lr
http://www.handelshuisdeurne.nl/index.php/component/sdelixer-winkel?artid=595&tree=1
Post by HighlyJetted on Thu Nov 27, 2014 8:29 am
Nice!!!
His trxx does not have the JBDET in it though. It has the 3 cylinder EF series engine instead.
But very nice find, I will post it on the kei forums.
Post by scotia on Sun Nov 30, 2014 10:49 am
Post by FrontBackSide2Side on Mon Dec 01, 2014 6:59 am
vast improvement Smile
Post by scotia on Wed Dec 03, 2014 4:29 pm
finished working on the coolingsystem today.
-replaced all hoseclips for decent ones
-replaced radcaps
-done pressuretest coolingsystem without thermostat
-fixed leaking thermostathousing
-tested thermostat and put it back in the correct spot, thermostat was new
-refil coolant the correct way and bleed the air the correct way.
in hindsight i didnt bleed the system correctly when i did the previous work on the engine.
and i didnt put the thermostat in the correct place.
and had a few leaks in the system and an old crappy radcap.
it runs good now  cheers
thermostat opens, al hoses get hot , fan kicks in .
no leaks anymore no airgap under the radcap under the seat.
the coolant stays on the same level in the tank.
drove it about for quit some time,
then let it run for 10 minutes in the parking spot.. nothing happened.
if it stays like this for a couple of days i think its fixed    cheers
thanx guys for the help and info on here
i realy appreciate it
Post by HighlyJetted on Wed Dec 03, 2014 10:05 pm
After you heat cycle it 5 or 6 times - e.g. fully cold, to fully hot, back to fully cold.
You will notice the coolant level in the heater tank bottle settles to an exact point.
Draw a line with pencil on the fluid level, then keep an eye on it for a few months. Check it sits on the line when fully cold before you set off in the morning.
Post by scotia on Thu Dec 04, 2014 6:56 am
ok i wil do that, thanx hj
Post by scotia on Thu Dec 04, 2014 10:38 am
i made some pictures in the same spot  Smile
alien
and some random nice ones
Post by oldie on Sun Dec 07, 2014 8:33 am
Coolio Cool Smile .
Post by Manuel_nl on Thu Dec 25, 2014 11:12 pm
And now it's for sale. Are you leaving us?
http://link.marktplaats.nl/m882487504
Manuel_nl
Post by scotia on Fri Dec 26, 2014 9:21 am
yes i am.
i am looking at a nissan vanette diesel and mitsubishi l400 for converting in to a camper.
a bit more comfort and space and i would like to drive diesel again.
i know its not the most logical course of action
to spend that much amount of time and money on it and then sell it
but i had a change of heart and some extra money.
so the time has come for the litle van to go to a new owner.
Post by andy pyke on Fri Dec 26, 2014 12:24 pm
Looks awesome!
andy pyke
Post by scotia on Fri Dec 26, 2014 3:05 pm
thanx Smile
Post by scotia on Fri Jan 09, 2015 6:17 am
the new owner will collect it saturday.
i am going to buy a nissan vanette E 2.3 diesel.
if one of you guys has tips or info or things i need to know about the vanette
i would realy appriciate it...
-a bit bigger
-airco for the pug
-reliable no nonsense diesel engine
-cheaper running on diesel
i want to thank you guys for the help info and laughs during the last year.
greetings from the netherlands alien
Post by Manuel_nl on Fri Jan 09, 2015 10:23 am
The Vanette was my first choise but I didn't want a diesel because of the extremely higher road taxes for privately owned.
Manuel_nl
Post by scotia on Fri Jan 09, 2015 3:09 pm
yeah you are right about that.
hijet 18 euro---vanette 100 euro affraid
i gave up a couple luxuries like my garagebox to compensate the costs a bit.
but yeah its a lot of money
and i dont even need a car  Laughing
i hope to get it on campertax if i do the conversion in time.
Post by PFM on Fri Jan 09, 2015 6:57 pm
€100????? Wow, that's cheap compared with here, and €18 is a bloody steal!
Post by Manuel_nl on Fri Jan 09, 2015 8:03 pm
Cheap? the € 100 is for one month!
Manuel_nl
