help no power
help no power
Post by drippy on Fri Jan 31, 2014 6:45 pm
hello can any one help me. i have no power to my glowplugs on my hijet 1.2 1994. i think it may be a relay but have no clue were it would be, i was thinking if i put a switch to live then to glow plug would that do the trick if all else fails thanks julie
drippy
Re: help no power
Post by johnnyboy666 on Fri Jan 31, 2014 6:57 pm
have you checked all the fuses frst?
johnnyboy666
Re: help no power
Post by johnnyboy666 on Fri Jan 31, 2014 7:29 pm
http://service.lombardinigroup.it/documents/Manuali%20Officina/English/Work%20Shop%20Manual%20FOCS%20matr%201-5302-351.pdf
That might help too if you havent already seen it
page 86 suggests that it might be worth checking the coolant temp sensor, then the glow plug controller/timer. Although I havent had mine very long, so i wouldnt be able to tell you where they are located Im afraid!
johnnyboy666
Re: help no power
Post by davidc on Fri Jan 31, 2014 7:41 pm
the glow plug relay on mine is under the passager seat
davidc
Re: help no power
Post by drippy on Sat Feb 01, 2014 11:29 am
Found 2 relays which one is it the short or the tall one?
drippy
Re: help no power
Post by davidc on Sat Feb 01, 2014 3:23 pm
it the tall one if you pull it out you will see 2 big connectors they are the ones from the battery to the glow plugs
davidc
Re: help no power
Post by drippy on Sat Feb 01, 2014 5:35 pm
Thanks I'm gonna scour the Internet in search of a new one thanks for your help
drippy
Re: help no power
Post by HighlyJetted on Sat Feb 01, 2014 7:50 pm
Just bridge the relay and make sure that is the fault.
Re: help no power
Post by ldv.tek on Tue Feb 04, 2014 9:57 pm
Hi there,
As already mentioned test the relay and glow plugs first.
Is the relay clicking, if not check the wiring on the relay to activate it.
If the relay is clicking then test the output using a voltmeter from the relay then at the each plug.
If I was in a fix with a glowplug relay I would purchase a 100 amp relay from Ebay for around £13, A switch for the dash for about £2.
Place the switch on the dash some where, wire up to activate the relay.
Attach wires to the relay for the live & glowplugs.
Run a wire to the Glow Plug light on the dash from the live side of the glow plug feed, this way the light comes on when you press the switch to activate the glow plugs but it will also stay on if you ever have issues with the contacts in the relay sticking.
ldv.tek
Re: help no power
Post by Logi on Tue Feb 04, 2014 10:01 pm
ldv.tek wrote:Hi there,
You Sir are deffo becoming the diesel guru  Laughing
Re: help no power
Post by ldv.tek on Tue Feb 04, 2014 10:43 pm
Many years of crap cars and vans and never enough funds to get them repaired  Very Happy
ldv.tek
Re: help no power
Post by ldv.tek on Tue Feb 04, 2014 11:41 pm
ldv.tek
Re: help no power
Post by ldv.tek on Tue Feb 04, 2014 11:42 pm
Needed a break from course work so decided to draw a quick diagram  Cool
ldv.tek
Re: help no power
