Hijet 660 CC High Fuel Consumption
Post by khanjet on Sun Feb 09, 2014 4:32 pm
Hi everybody
I am Stori from Pakistan! I bought a daihatsu Hijet 2009 Van! Its a 660 cc automatic transmission vehicle! I am facing some problem and seek your technical guidance in this regard! the fuel consumption is very high! It gives around 10 kmpl in semi urban! I changed the spark plugs,air filter and tuned the engine! But still no change in the mileage!
Plz help me!
khanjet
Re: Hijet 660 CC High Fuel Consumption
Post by craig2859 on Sun Feb 09, 2014 7:20 pm
10km pl ..... Have you got a fuel leak !!
craig2859
Post by PFM on Sun Feb 09, 2014 9:54 pm
Welcome, Stori. It's equivalent to about 28mpg. Small engine with autobox - what do you think you should get?
Post by khanjet on Mon Feb 10, 2014 4:37 pm
The rivals claim 16 to 18 Kilometers per liter. How could I check fuel leak?
khanjet
Post by khanjet on Mon Feb 10, 2014 4:38 pm
PFM wrote:Welcome, Stori. It's equivalent to about 28mpg. Small engine with autobox - what do you think you should get?
The rivals claim 16 to 18 KMPL.
khanjet
Post by craig2859 on Mon Feb 10, 2014 7:33 pm
Aha, I was thinking MPG, Apologies.
I suppose it could be a number of things:
Tyre Pressure
Fuel Pressure Regulator
Coil
HT Leads
Worn Timing Belt
craig2859
Post by HighlyJetted on Mon Feb 10, 2014 11:26 pm
Well your getting 29.7mpg
Which is really not bad if you live in a hilly area and you carry a load.
But if its empty and flat, then it is poor.
I would look at:-
Is the cam timing correct
Is the ignition timing correct
Is the ignition system in good condition
Is it using all of its gears - does it make it to the overdrive gear.
Are the brakes not binding.
Are the tyres correctly inflated.
Post by khanjet on Fri Feb 21, 2014 2:12 am
Thanks a lot to all for your so kind support! I will check these things & would let u know!
khanjet
Post by El_Ventu on Thu Mar 20, 2014 11:02 am
Mine,but it's a 4x4 one with somr load and winter tires always on, has a fuel consumption of 8.5/9 km/l on lpg...
El_Ventu
