diagnostic connector location
Post by KIELENKELE on Wed Feb 12, 2014 1:58 pm
Hello everybody
Can someone tell me where is the diagnostic connector of daihatsu hijet cargo 659cc,065L made in 2001? How many pins does it have and what colours are T and E cables?
KIELENKELE
Re: diagnostic connector location
Post by HighlyJetted on Wed Feb 12, 2014 2:42 pm
Might be obd2 under the dash on the drivers side.
Post by neil54 on Thu Feb 13, 2014 7:25 pm
I found mine behind the fuse box, left hand side of steering column, tucked behind the carpet.
It is only has four connectors.
There is an article concerning the flashcodes and I think from memory the T wire is brown.
neil54
Post by KIELENKELE on Fri Feb 14, 2014 6:23 am
Thank you very much my friend, I work far from my house, so tomorrow I will look for it and then let you know wheither I found it or not. But in the midletime, can you tell me if it is alone or sticked with another plug and what colour is it.
KIELENKELE
Post by HighlyJetted on Fri Feb 14, 2014 9:33 am
Yours being a 2001 Cargo 660 EF-SE engine model s200 or s220 will most likely be like this http://www.daihatsuhijet.co.uk/s200-extol-atrai-cargo-hijet-engine-diagnostic-mode-and-error-codes/
Post by KIELENKELE on Wed Feb 26, 2014 3:21 pm
Hello Highly Jetted
Mine is a 659CC EF-SE engine model GD-S200V 0.65l made in 2001 in Japan. It is slightly different with what i saw to www.daihatsuhijet.co.uk/s200-extol-atrai-cargo-hijet-engine-diagnostic-mode-and-error-codes/
KIELENKELE
Post by HighlyJetted on Thu Feb 27, 2014 12:00 am
Can you post any pictures of what you've got?
Post by KIELENKELE on Wed Mar 19, 2014 12:34 pm
The DLC of my car is a black 16 pins one, using only 8 wires. Here is the connection of wires:
1st pin (green-black)--------------54
2nd pin not used
3th pin (black)---------------------6
4th black-white)-------------------11
5th not used
6th (white-violet) -----------------31
7th (yellow)------------------------12
8th not used
9th (red-yellow)--------------------29
10th not used
11th not used
12th not used
13th (violet) does not go to the ecu
14th not used
15th not used
16th black-red--------------------11
As you it is not the same. Example:according to daihatsu hijet .co.uk, 16th pin is for the battery power but for my DLC is ground.
KIELENKELE
Post by HighlyJetted on Wed Mar 19, 2014 8:01 pm
What happens if you plug an OBD2 code reader into it?
Post by KIELENKELE on Mon Mar 24, 2014 10:21 am
I have not it, and i would like to know first of all what kind of OBD is it, OBD, OBD1 or OBD2.
KIELENKELE
Post by HighlyJetted on Mon Mar 24, 2014 11:05 am
OBD2 if it looks like this:-
Post by KIELENKELE on Tue Mar 25, 2014 9:54 am
Yes, it does. But the problem is in the connexion from dlc pins to ecu pins. It is not the same with the one i saw to www.daihatsuhijet.co.uk, as i wrote to you first.
KIELENKELE
