Hijet 993cc 1994 wont run without choke
Post by 77JRAW on Sun Feb 16, 2014 1:23 pm
Hi all,
We have recently purchased a Daihatsu Hjiet Pickup 993cc 1994. It starts but only with choke fully out! Has anyone had this problem, if so how did you go about it?
Joe
Last edited by 77JRAW on Sun Feb 16, 2014 3:36 pm; edited 1 time in total (Reason for editing : spelling error)
77JRAW
Re: Hijet 993cc 1994 wont run without choke
Post by HighlyJetted on Sun Feb 16, 2014 1:50 pm
Most of us are running EFi Hijets.
But normally a carb engine that will only run on choke has clogged up idle jets.
Post by 77JRAW on Sun Feb 16, 2014 3:38 pm
Okay, i was thinking they made need a clean.
77JRAW
Post by bushwhacker on Mon Feb 17, 2014 12:32 pm
It is normal for a carburettor engine to start from cold with the choke fully out. That is what it is for.
Post by 77JRAW on Mon Feb 17, 2014 8:14 pm
I know that, it won't run after 10-20 mins of running. Like HighlyJetted said the carb needs a clean
77JRAW
Post by jamesstanley on Mon Feb 17, 2014 9:31 pm
Nice to see someone else with a carbed 993!
It's got the most complicated carb I've ever seen (admittedly I'm used to motorbikes) but it's easy enough to get it reinstalled after removing it if you take care of where all the vacuum lines have to go...
jamesstanley
Post by 77JRAW on Mon Feb 17, 2014 9:59 pm
Ok thanks. We are going to take lots of pictures and mark it all up so it all goes back perfect.
77JRAW
Post by HighlyJetted on Mon Feb 17, 2014 10:15 pm
If the carb bowls have rust in them then you need to address you fuel filter and rotting petrol tank. Rotting petrol tanks are normal on Hijets Smile
