sliding doors
sliding doors
Post by piaggio05 on Sun Feb 23, 2014 6:22 pm
the sliding doors tend to fall of the runners on my piaggio porter , the top runners seem to be very battered , also when the door is shut and locked it works itself open when i am on the move , luckily it only comes open a little bit but this is a big problem causing lots of noise and draft. any ideas ?
piaggio05
Re: sliding doors
Post by Logi on Sun Feb 23, 2014 6:55 pm
Any ideas? Yeah, I wouldn't use your e-mail addy as your user name...
Doorlocks and sliding door bearings, common Hijet maladies, never fear HJ will be along soon to help you out Smile
Re: sliding doors
Post by PFM on Sun Feb 23, 2014 10:45 pm
Another Porter owner? Welcome. Neither sliding door of my '08 van fitted right when I got it - am gradually getting there though. Think the build quality may have deteriorated over the years. When they shut, do your doors look flush with the rest of the van?
Re: sliding doors
Post by piaggio05 on Sun Feb 23, 2014 11:18 pm
Hi yes 05 model, the sliding door catches on the front passingers
piaggio05
Re: sliding doors
Post by piaggio05 on Mon Feb 24, 2014 12:05 pm
i have spent a lot of money on this van dont want to spend much sorting out the doors ,would it be possible to fix a bracket to keep the door closed permanently or is this not allowed for mot purposes
piaggio05
Re: sliding doors
Post by PFM on Mon Feb 24, 2014 2:45 pm
It shouldn't cost anything to sort unless something is missing. First, I'd compare the location (where they attach to the door) of the top and bottom guides with the door on other side and adjust if necessary. To get to the centre arm you need to remove the door card. This one can be adjusted with the door shut and I'd do this next to get the door perfectly lined up in the aperture, then re-check the top and bottom guides.
Oh, and if anyone wants a new n/s door: http://www.ebay.co.uk/itm/191080407035?ssPageName=STRK:MEWAX:VRI&_trksid=p3984.m1423.l2661
Re: sliding doors
Post by Webolution on Wed Jan 28, 2015 3:50 pm
PFM wrote:It shouldn't cost anything to sort unless something is missing. First, I'd compare the location (where they attach to the door) of the top and bottom guides with the door on other side and adjust if necessary. To get to the centre arm you need to remove the door card. This one can be adjusted with the door shut and I'd do this next to get the door perfectly lined up in the aperture, then re-check the top and bottom guides.
Very helpful! I have the same problem and door cards are out. Now I have to look for the centre arm and see if I can adjust the door that is not closing properly.
THANKS PFM!
Webolution
Re: sliding doors
Post by PFM on Wed Jan 28, 2015 7:13 pm
Do you have exactly the same problem? It is unlikely the centre arm has mis-adjusted itself on the door unless there is damage or someone has tampered with it.
Re: sliding doors
Post by Webolution on Thu Jan 29, 2015 11:42 am
PFM wrote:Do you have exactly the same problem? It is unlikely the centre arm has mis-adjusted itself on the door unless there is damage or someone has tampered with it.
What a bad surprise I found behind the door card...not only someone has tampered with it (as you said), but also I found a terrible welding work inside and a big hit hammered, filled and repainted from outside...I think it's not going to be easy to fix the sliding doors properly.
Webolution
Re: sliding doors
