help please
help please
Post by waz on Tue Feb 25, 2014 6:28 pm
wifes car is a Fiat Doblo, for the past week stating first thing in the morning you would think it had a flat battery. I have had it checked at the garage and they said the battery is ok and can't find anything draining it so now I am at a loss. Any ideas or should I try a auto electrician.
Re: help please
Post by PFM on Tue Feb 25, 2014 7:32 pm
Connection, connection, connection? Am sure you checked battery terminals, but dodgy lead to starter, earth to engine, earth to body joints could give same symptoms.
Re: help please
Post by waz on Tue Feb 25, 2014 8:08 pm
PFM, Hopefully all been done by the garage but will check myself next dry day.
Re: help please
Post by FrontBackSide2Side on Wed Feb 26, 2014 6:24 am
Don't rule the battery out completely as i've had batteries tested in the past and been told they are ok then once they have been changed the problem is cured.
Re: help please
Post by johnnyboy666 on Wed Feb 26, 2014 2:58 pm
I've also had a battery that tests fine but is actually not . My money would be on that or the starter wiring
johnnyboy666
Re: help please
Post by PFM on Wed Feb 26, 2014 10:03 pm
Why not swop your Hijet battery into it for a while and see the difference?
Re: help please
Post by waz on Wed Feb 26, 2014 10:37 pm
Well according to the book the battery is not charging but I would have thought that the garage would have pick that fault up assuming that it could be the alternator at fault. Mind you the oil leak they were supposed to fix is still leaking so back up there tomorrow.
Re: help please
Post by waz on Thu Feb 27, 2014 5:04 pm
Sorted I hope, auto electrician said it was the battery, so popped a new one in
Re: help please
