indicators no worky
indicators no worky
Post by melboy on Fri Mar 14, 2014 1:30 pm
the front indicators on bumper dont work but side and rear do but flashing faster than normal.
looked for earth connections but cant find them.
checked bulbs all ok and cleaned wire connecters behind.
im stuck for ideas now,what should my next step be? Sad
melboy
Re: indicators no worky
Post by GEORDIE on Fri Mar 14, 2014 1:50 pm
my suggestion would be
get the multimeter out and check
that you have 12v at the connecters
at the lamps,if you dont have a meter
well worth having at not much cost
about £5 for a basic one
good luck ken
GEORDIE
Post by melboy on Fri Mar 14, 2014 2:00 pm
ive got one geordie and ive 4-5volts at connecter behind indicator.
so thinking short or loose earth?
melboy
Post by HighlyJetted on Fri Mar 14, 2014 4:05 pm
Test the live with the other probe conencted to something metal (I use the ignition barrel)
If the live is still only 5v I would test to see if your getting 12v at the switch on the indicator stalk. Maybe test at the relay too.
Post by melboy on Fri Mar 14, 2014 4:45 pm
is that the blue relay near nearside headlight?
melboy
Post by Guest on Sat Mar 15, 2014 12:09 am
Oh no Mel !! Not the dreaded blue relay syndrome again. Take a hammer to it this time.  Rolling Eyes Embarassed affraid
Post by melboy on Sat Mar 15, 2014 8:47 am
yes stuart fixed fogs and now bumper indicators playing up, Sad Sad
melboy
Post by Guest on Sat Mar 15, 2014 9:49 am
It does sound like a poor earth problem Mel. Going back to that troublesome blue relay if you stick your head back up under the dash again with the glovebox removed there are a couple of earth wires alongside the Central Locking Relay and the wires disappear through the headlight hole. Not sure if its the earth for the indicators as well but worth another look perhaps Mel.
Finally going on Monday to Dover to pick up the wheels now my leg is up to the drive. Around 340 miles round trip. silent Sad Sad
Post by melboy on Sat Mar 15, 2014 10:32 am
thought you did trip thursday,looked where you said and there is a earth at back of central locking module and blue relay.
melboy
Post by singledad on Mon Mar 17, 2014 2:12 pm
is that 340miles in a hijet!! your back will be sore next lol
singledad
Post by Guest on Mon Mar 17, 2014 2:50 pm
Nope Ron. Just done it in my 2000 Ford Focus. Waiting at Portsmouth now having been to Dover and back to Pompey by 13-45 but couldn't get on 14-00 Ferry. Some lovely Alloys. Piccies later.
Post by Logi on Mon Mar 17, 2014 5:52 pm
woody wrote:Nope Ron. Just done it in my 2000 Ford Focus..
Poof!  Razz
Post by Guest on Mon Mar 17, 2014 6:33 pm
There's absolutely no hope for you is there Logi ??
Totally incorrigible !!
I might go up in a poof of smoke at the Crematorium
eventually, but but I certainly won't go up where you are intimating. Nothing could be further from the
truth.  Rolling Eyes Mad Evil or Very Mad
