ign/door key numbers
Post by metalmick on Thu Mar 27, 2014 8:46 am
had the joy of snapping my ignition key, whereabouts are the key numbers or how do i go about this, unfortunately i only have the one key and its also fits the other 2 locks "R" reg hijet pick-up tipper
ta mm
metalmick
Re: ign/door key numbers
Post by HighlyJetted on Thu Mar 27, 2014 10:07 am
If you take the two halfs of the key to a decent key cutting place they will make you another.
I don't think you can just cut from the ID number..... Daihatsu dealers might be able to, but don't hold your breath!
Post by metalmick on Thu Mar 27, 2014 10:14 am
ta for that , i figured taking the two halves in, always worth asking though and thankfully i happened in my yard and not out and about
mike
metalmick
Post by johnnyboy666 on Thu Mar 27, 2014 6:33 pm
my ignition has half the key stuck in there, i just use the remains of the key as normal and its fine. I do have a spare key for the doors though
johnnyboy666
Post by Guest on Thu Mar 27, 2014 9:03 pm
If you get stuck I have ignition/steering locks with keys I can send out to you. Might even be able to scrape up a matching set of locks and ignition lock.
Post by metalmick on Thu Mar 27, 2014 9:18 pm
thanks,i really appreciate the help, i have a local fella that does keys and such, so will see him tomoz
ta mike
metalmick
Post by Logi on Fri Mar 28, 2014 5:56 am
Can't remember offhand the company but i sent away for a replacement key by sending them a picture of the key, surprisingly it fitted perfectly.
Post by Guest on Fri Mar 28, 2014 7:35 am
That is amazing Logi. Our local hardware store can't even get it right when they cut from the original key !
Post by Logi on Fri Mar 28, 2014 12:50 pm
When I'm on the laptop I'll post up a link, they were quick and way cheaper than Timpsons too, they wanted twenty odd quid for the chip key and it was about seven posted from these guys.
