Vented or solid discs
Post by xxemaphorr on Wed Apr 02, 2014 10:27 am
Does anyone know if they really did fit vented front brake discs to the 1.3 hijet? Mine was made in 05/98 and so is right on the changeover to the new type vehicle and has solid discs. Everywhere I check for parts though they all ask this question. If this is true are the calipers any different? I would expect there to be some difference in thickness or diameter. Has anyone driven both and noticed a difference in stopping power?
xxemaphorr
Re: Vented or solid discs
Post by FrontBackSide2Side on Wed Apr 02, 2014 11:36 am
My 2003 has solid discs.
Post by HighlyJetted on Wed Apr 02, 2014 2:11 pm
All are solid to my knowledge!
Post by Guest on Fri Apr 04, 2014 12:30 am
Likewise.!! Every Hi-Jet I have had or scrapped have been solid discs.
And yes if there were Vented Discs the calipers would be wider to accommodate the extra thickness of the vented disc. But its a nice thought though.
Post by d1noh on Fri Apr 04, 2014 7:04 pm
Why on earth would anybody need vented discs on a hijet, keeping them going forwards or backwards under their own power is the biggest problem the last thing you want to do is stop them  Laughing
Post by Logi on Fri Apr 04, 2014 7:05 pm
Mine's has vented discs?
Post by Guest on Fri Apr 04, 2014 7:06 pm
Rust Moths ??
Post by Logi on Fri Apr 04, 2014 7:13 pm
Nah, was just having a bit of variety, mines are solid too Wink
Post by PFM on Fri Apr 04, 2014 7:23 pm
I'm with d1noh - what would be the point (apart from adding cost)?
Post by FrontBackSide2Side on Fri Apr 04, 2014 7:43 pm
maybe good for the 1.6 engine swap Smile
Post by d1noh on Fri Apr 04, 2014 8:01 pm
Always gets me when people say: Got vented drilled Discs, the best brake pads money can buy, my reply is when did you last change your brake fluid and you get the reply Why?
Wonder how many people change brake fluid regularly?
Post by davidc on Fri Apr 04, 2014 9:12 pm
i had a l reg 1.0 carb it had vented discs the calipers was the same as solid discs it also had the cv cups built on to take a drive shaft
davidc
Post by HighlyJetted on Fri Apr 04, 2014 9:46 pm
If the vented are the same thickness as solid then they must have a much lower thermal mass to play with.
Anyway I rarely cook the brakes on mine and it get some serious b lane hammering round tight corners and lots of down hill thrashing.
Post by xxemaphorr on Wed Apr 09, 2014 2:07 pm
Well it seems solid are the only option! I'm happy with that though; always been fairly happy with the hijet brakes I just thought I'd investigate a little! Thanks for your input everyone
xxemaphorr
