New Member - with an oldish Piaggio Porter Van
Post by Chassyh on Thu Apr 03, 2014 3:54 pm
Hi
Ive joined this forum to find out more about Piaggios and their older cousins Daihatsu Hijets. There seems to be not much info on the net, very little help from dealers including the main one in Hull. New spares are impossible to get/crazily expensive, I'm patching my '56 Porter up with second-hand Hijet spares!!
Does anyone know of an engine fault code reader that will work on our machines? Or a work-around to help identify why the Engine Management Light is on, and how to switch it off.
Chassyh
Re: New Member - with an oldish Piaggio Porter Van
Post by Logi on Thu Apr 03, 2014 4:12 pm
Hi, welcome to the wacky world of Hijets Smile
Any cheap obd reader will work, socket is under the dash rhs. Mine cost a tenner delivered.
http://www.ebay.co.uk/itm/Car-Diagnostic-Scanner-Fault-Code-Reader-Tool-CAN-BUS-OBD2-II-EOBD-EOBDII-U480-/150987229373?pt=UK_Diagnostic_Tools_Equipment&hash=item23278a48bd
Post by FrontBackSide2Side on Thu Apr 03, 2014 4:55 pm
Welcome to the forum!
I bought a Vgate VS600 OBD2 tool and am very impressed with it. I think they are around £25 so a bit more than the one Logi has but i'd definetley recommend it, although i haven't seen Logi's.
Post by PFM on Thu Apr 03, 2014 7:12 pm
Another welcome. Where in the world are you?
I've heard that not many people have seen Logi's....
Post by Chassyh on Thu Apr 03, 2014 7:32 pm
I'm in North Staffordshire, the van performs well at altitude until the snow falls then it don't go anywhere!! That rear wheel drive has a lot to answer for!
Chassyh
Post by FrontBackSide2Side on Thu Apr 03, 2014 7:36 pm
i'm yet to experience the snow in mine but its bad enough in the wet. Think its because its so light on the back!
Post by Chassyh on Thu Apr 03, 2014 7:51 pm
Hmm I know what you mean, but I'm more concerned with the high winds I get around here, so much so that I have sorted a 'Windy route' to get to places when I need to be there in adverse conditions!! I need the reader as I have a recurring Oxygen sensor problem, the management light comes on, I have it cleared, it stays OK for maybe a month then deja vu! Wonder if this is a common problem?
Chassyh
Post by FrontBackSide2Side on Thu Apr 03, 2014 7:55 pm
I'm having the same code but i think mine is caused by a misfire throwing un burnt fuel into the exhaust thus giving the O2 sensors strange readings.
Post by HighlyJetted on Thu Apr 03, 2014 11:28 pm
If your in north Staffordshire and you get stuck you could always bring it to my garage in Congleton. Wink
Post by Guest on Fri Apr 04, 2014 12:06 am
Yes I too have got the V-Gate 600 scanner though I was obviously robbed as I paid £30 each for the two I bought.
Has got me out of trouble several times but I am still learning how to use its many functions.
Welcome to Hi-Jet World. You will certainly find all of the help you need on this superb Forum.
Post by Chassyh on Fri Apr 04, 2014 12:11 am
HighlyJetted, I'm 'On the Moor' so only a cockstride from you, where is your garage situated in Congleton?
Chassyh
Post by Guest on Fri Apr 04, 2014 12:13 am
Talking of snow as you were. I put 10-12 bags of sand in the back of mine and it goes where even Land Rovers struggle --- though that's not hard thinking about it. Hideously hopeless horrible heaps !!!
Post by HighlyJetted on Fri Apr 04, 2014 12:29 am
I am at the very bottom of Royal Street, past threadfast and congleton glass.
Post by Chassyh on Mon Apr 14, 2014 6:05 pm
Thanks one and all, I have purchased a V-Gate 600 from EBay, my local motor shop man doesn't sell any scanners as they are 'Too specific'.
Plugged in, found the error I was expecting - Oxygen sensor Bank 2, cleared the codes, all peachy. Light has not (yet) come back on, but I know what to do when it does!!
Thanks again. HighlyJetted, I have viewed your establishment on Google Earth. I will try and pop in when I'm in town if that is OK by you ??
Regards
Chas
Chassyh
Post by PFM on Sun Dec 21, 2014 10:10 pm
So, Chas - did you ever make it to HJ's Palace? HJ - did he ever arrive?
Post by HighlyJetted on Mon Dec 22, 2014 8:19 am
Don't think so, but keeping track of real life names and forum usernames is more than I am capable of.
