handbrakecable partnumber
Post by scotia on Tue Apr 08, 2014 2:07 pm
hi, yesterday i failed the mot because of left and right rear (outer?) handbrakecable.
i am trying to get the parts but that doesnt seem as easy as it sounds.
i found a website that does sell them but the site shows mee 6 different kinds..
could one of you guys help me out and tell mee what cable i should get?
or does somebody have the original part numbers ?
34-vs-sf hijet van 1,3 16v 2000
this is the site i mentioned
http://www.winparts.nl/remsysteem/remkabels/daihatsu/hijet-ii-box--s85--bouwjaar-1992-12----/c637-554-14146.html?msg=geenautospecifiek
Re: handbrakecable partnumber
Post by melboy on Tue Apr 08, 2014 3:37 pm
have you tried ebay?
melboy
Post by HighlyJetted on Tue Apr 08, 2014 7:41 pm
I cannot give you exact answer!!
It is not these parts:- 0316181 or 0316154
The two cables are different lengths for each side, so you cannot put a left on a right.
So the remaining 4 parts numbers are 2 x left and 2 x right.
I am unsure which you need.
If you are unsure, there are engineering shops which make cables while you wait for pretty much anything. They are used in industry for factories, boats, diggers etc etc. I use this one http://www.rdb93.co.uk/ near me but you will find one local to yourself. Expect to pay around £30 per cable. Just take in your damaged/broken cable and they will copy it.
Post by scotia on Wed Apr 09, 2014 9:16 am
thanx for the tips , i think i will look up a shop that makes cables.
i will post the anwser if i fixed it
