Wanted Wiring Diagram 1997 Hi-Jet 1.0 6 Seats
Post by derekmwalshaw on Fri Apr 18, 2014 8:03 am
Hi all. I desperately need the wiring diagram for my 1997 Hi-jet 1.0 6 seats.
Recently I have had a fault with the indicators. The left hand side started flashing very fast, but both bulbs were ok. It was very intermittent, They have been working normal now for a while. Then the horn stopped working.
So I took it to my local Hi-jet breakers to have another horn fitted. Turns out the horn was ok, and suggested there could be a fault in the unit. He had a Indicator unit so we tried that. Uncoupled the 2 plugs on mine that connects the loom, and tried the one he had. Still no joy. We connected mine back up. all was working fine except the indicators. The were working ok outside but not flashing on the dash. Horn still not working
I then stated messing with the 2 plugs to see if they were pushed together properly. Doing this I was moving the loom all over. Plugs were fine, Checked indicators, now flashing on dash, but the R/H side indicators are again, flashing fast. Horn still not working.
This all this points to a loses or badly connected wires around the plugs. My mate who's brill with electrics will have a look but needs the wiring diagram.
Any help appreciated. Cheers
derekmwalshaw
Re: Wanted Wiring Diagram 1997 Hi-Jet 1.0 6 Seats
Post by HighlyJetted on Fri Apr 18, 2014 10:16 am
Post by derekmwalshaw on Fri Apr 18, 2014 3:24 pm
HighlyJetted wrote:You will find it on this page http://www.daihatsuhijet.co.uk/manuals-downloads/
here is the diagram you want:-
http://www.daihatsuhijet.co.uk/pdf_manuals/efidiagram.jpg
Thanks mate! Just the job cheers
We will get stuck in after Hols Very Happy
derekmwalshaw
