Signal Turn Relay?
Signal Turn Relay?
Post by derekmwalshaw on Wed Apr 23, 2014 5:37 pm
Help please!
Where is the Relay switch for the indicators on a 97 Hi-jet 1.0 efi pleas. Nothing in the manual. left side indicators sometimes keep flashing fast with both bulbs working
Cheers
derekmwalshaw
Re: Signal Turn Relay?
Post by melboy on Wed Apr 23, 2014 6:47 pm
had the same problem and found bad connection at the plug behind the light,the relay is on top of fusebox under dash
melboy
Post by derekmwalshaw on Wed Apr 23, 2014 7:07 pm
melboy wrote:had the same problem and found bad connection at the plug behind the light,the relay is on top of fusebox under dash
Cheers  Very Happy
I will check the wiring back of the indicator First
derekmwalshaw
Post by PFM on Wed Apr 23, 2014 7:43 pm
Both bulbs? Should be 3 working per side - 1 at rear, 1 in front bumper and one in corner housing. I've had trouble with the connector to the front bumper indicator.
Post by HighlyJetted on Wed Apr 23, 2014 7:55 pm
Yeah those plugs get some serious weather.
