Propshaft staked universal joint replacement.
Post by ldv.tek on Thu Apr 24, 2014 9:51 am
Hi to all,
Propshaft off vehicle, UJ's removed now need to source a replacement.
The Bearing caps measure 24mm across, does any one know of a source or the dimensions of the UJ I need.........reason for asking is they had to be cut out with a grinder and not much left to measure now  Sad
Its not the smaller 22mm universal joint as used with circlips as I had one of thse too hand.
Any help welcome  Surprised
ldv.tek
Re: Propshaft staked universal joint replacement.
Post by Logi on Thu Apr 24, 2014 10:52 am
Think Woody sourced replacement joints if i remember correctly?
Did you try for a warranty shaft?
Post by ldv.tek on Fri Apr 25, 2014 11:14 am
My van is a Piaggio Porter with the staked joints so I dont think its covered on the recall.
Update - Old UJ'sw out of the prop, after much measuring and part number matching and sourcing I have found some bearings, ordered them just now for a mere £18 for the pair delivered.
I had sourced the original bearings but was not willing to pay inflated prices of £30-35.
Photos have been taken of bearing removal, will take photos of bearing replacement and staking them in and post pics up with details for other people once done  Very Happy
ldv.tek
Post by HighlyJetted on Fri Apr 25, 2014 8:39 pm
How will you stake them in with accuracy?
Post by ldv.tek on Sat Apr 26, 2014 8:27 pm
All going well insert Spider, slide in bearing caps, measure depth of bearing caps with a dial gauge, hammer and drift and pleen over the metal.
Above is theoretical  Very Happy
ldv.tek
Post by HighlyJetted on Sat Apr 26, 2014 9:50 pm
Good luck with that yeah!
Don't pean it a mm too much or you'll clamp the UJ.
Dont pean it enough and it will rattle itself to bits.
And if you dont get it bob centre it'll shake itself to bits.
Not being negative or anything =)
Post by ldv.tek on Sat Apr 26, 2014 10:01 pm
Aye, its going to have to be pretty accurate ;-)
ldv.tek
