Shear hell! How to deal with snapped bolts?
Post by harrythehamster on Thu May 01, 2014 4:19 pm
In the process of removing my air filter housing I removed the plastic guard from underneath but have sheared all three bolts holding it on.
I sprayed them with WD and was very gentle but they just snapped anyway.
I've never had this problem before and wonder what the best way of removing the sheared bolt from the hole is?
harrythehamster
Re: Shear hell! How to deal with snapped bolts?
Post by FrontBackSide2Side on Thu May 01, 2014 4:26 pm
It will be near impossible if they are rusted in, i would drill them out and retap them Smile
Post by Lab_Rat835 on Thu May 01, 2014 6:22 pm
best way is use a stud extractor with loads of heat here is a link t a cheap set on ebay
stud extractor
Lab_Rat835
Post by HighlyJetted on Thu May 01, 2014 6:50 pm
Ive given up with easy out stud extractors, worst case is you snap them in them in situe and they are a bitch to drill out.
I just drill out snapped bolts the helicoil down to the original size.
Originally I thought it was because I was using cheap easy outs, so I bought some expensive ones but they were no better.
Post by FrontBackSide2Side on Thu May 01, 2014 8:00 pm
Easy outs are only any good if the sheared bit of the pin is free in my experience, even then i use a hammer and centre punch.
Post by Logi on Thu May 01, 2014 9:10 pm
FrontBackSide2Side wrote:Easy outs are only any good if the sheared bit of the pin is free in my experience, even then i use a hammer and centre punch.
^^^^^^ THIS
They only work if the bolt is slack, whereas then if it was slack you wouldn't snap the bugger in the first place!
Post by HighlyJetted on Thu May 01, 2014 11:42 pm
They turn the stuck bit of stud into more like a rawlplug at the easy out expands the drilled out tube more and more as you put force onto it only making it bind harder.
Post by FrontBackSide2Side on Thu May 01, 2014 11:53 pm
Very true!
Post by Logi on Fri May 02, 2014 6:03 am
A portable mini welding kit is a lifesaver, wee ones with Mapp gas are available for around the hundred quid mark, not much use for welding really but as a heat source it'll save you from loads of hassle.
Post by HighlyJetted on Fri May 02, 2014 8:29 am
I love my turbo torch with a bottle of MAPP gas.
It is loads hotter than propane or butane, and the turbo torch flame shape is really focused and intense.
Post by Lab_Rat835 on Fri May 02, 2014 8:55 am
HighlyJetted wrote:I love my turbo torch with a bottle of MAPP gas.
its what i use^^^^
easy outs can break if you put too much force on them, the trick is plenty of heat and just feel it, i have had mine years and never had a problem, i have even removed sheared wheel studs with them
Lab_Rat835
Post by ldv.tek on Sat May 03, 2014 3:32 pm
Another method is too weld a nut onto the remains of the stud.
Can be used with a protruding stud or if its been snapped flush.
The heat from the weldor free's it up and you have a nut to use a spanner socket set rather than swearing with easy outs, drill, mole grips etc.
Doesnt work in all scenarios but another excellent method, saved me many hours over the years.
ldv.tek
Sorted!
Post by harrythehamster on Wed May 07, 2014 9:07 pm
Tried extractors. Naff. Bolts were like the had been welded in and weren't budging although I did manage to get the extractors out.
I ended up drilling straight through in increasing sizes of bit and fitting new bolts through the hole and fixing with nuts underneath.
Took bloody ages though!
harrythehamster
