Staked UJ replacement.
Post by ldv.tek on Sat May 03, 2014 2:40 pm
This is a quick "how I did it" and not a "how to guide", take any of this information and use it at your own risk.
Bearings - 24mm bearing caps and 63.3mm accross, £3.80 each.
Bearings are from a BMW/Mercedes - Part number GU200.
Original bearings for the prop were 24mm x 62.5mm, odd size and expensive as the cheapest I found them for was £30 each.
The extra 1.3mm isnt going to make a difference because there is no circlips to worry about.
Step 1
* Press out UJ's and remove bearing caps.
* You could use a reaming tool to remove the metal that holds in the bearing caps.
* We didnt have that option to hand so welded a bar to the cap and tapped/twisted them out.
Step 2
Clean out any of the remaining metal that was holding in the bearing caps.
Step 3
* Insert the new UJ's and bearing caps.
* You wont have circlips so you need to centralize the UJ yourself.
* We pushed the bearing caps in so they just engaged with the spider without pinching tight.
Step 4
* Cut 4 notches into the prop around the bearing cap areas.
* Clean well once done.
Step 5
* Make sure the bearings are still centralized.
* Drop on a washer the right size so it sits on the bearing cap.
Step 6
* Weld 4 spots to hold the washer on.
* Go back to 5 and repeat another 7 times  Very Happy
Step 7
* Admire the resulting farm yard mechanics.
Now for the important bit, does it work.
Yes, test drove the van today, vehicle is quieter than before, will drive on tickover (wouldnt before because of the seized UJ).
A small amount of vibration at approx 3000-3500 revs but not enough to pinpoint to the propshaft, could be backlash in diff etc etc.
Is it worth doing - yes if not in a hurry and you like playing mechanics.
Will update this post when the UJ's fail if they do  Laughing
ldv.tek
Re: Staked UJ replacement.
Post by HighlyJetted on Sun May 04, 2014 1:57 pm
Pretty good job that!
Post by Logi on Sun May 04, 2014 4:11 pm
Well worth trying if yer shafts shafted, so to speak Wink
Post by johnnyboy666 on Sun May 04, 2014 11:43 pm
My shaft is shafted, but its the circlip type, would I just be able to do this but reuse the circlip instead of welding?
johnnyboy666
Post by ldv.tek on Mon May 05, 2014 10:34 am
Staked UK's are not designed to be a servicable part by the average home mechanic hence the guide.
UJ's with circlips are much easier to do and easy enough for most home mechanics.
A good vice, some patience and a little know how and you are done. Rather than rewrite whats already been covered by many I suggest a quick google search for how to replace UJ's and you will find a good guide I am sure.
One hint I would say is place the new bearings in the freezer the night before, this way they usually shrink enough to just drop into place  Smile
Also the bearing sizes are different, I dont have the size for the UJ's with circlips.
ldv.tek
Post by ldv.tek on Thu May 15, 2014 11:14 am
Update - Prop passed the MOT last week........woohoo.
ldv.tek
Post by HighlyJetted on Thu May 15, 2014 3:43 pm
Didn't think the prop shaft was part of the MOT.
Post by FrontBackSide2Side on Thu May 15, 2014 3:59 pm
Yeah, i'm pretty sure if there is excessive play in the prop it's a fail.
Edit- Just checked, i don't think it is actually. I think it can go down as an advisory though.
Last edited by FrontBackSide2Side on Thu May 15, 2014 4:07 pm; edited 1 time in total
Post by HighlyJetted on Thu May 15, 2014 4:06 pm
I'm half sure its not a test item..... half sure!
CV boots are, and a visual inspection of front drive shafts.
But no prop shaft inspection criteria.
But they could advisory it at testers discretion, or if dangerous fail the vehicle if it looks like a major hazard.
Post by FrontBackSide2Side on Thu May 15, 2014 4:08 pm
Sorry HJ, i just edited my post above Wink
Post by ldv.tek on Thu May 15, 2014 11:58 pm
Never had a prop fail an MOT but have had an advisory for play in a UJ before.
ldv.tek
ldv.tek
Post by johnnyboy666 on Fri May 16, 2014 9:28 pm
I've taken some inspiration from this thread, and have tracked down a suitable UJ to repair my 'cut'n'shut' propshaft, going to fit it all together at the weekend, and hopefully get the pickup in roadworthy condition again!
johnnyboy666
Post by ldv.tek on Sat May 24, 2014 9:56 pm
Update - Repaired prop developed vibration, once removed front bearing had gone notchy, ho hum.
Cant be bothered to mess about with the staked prop again.
Picked up a circlipped prop for free (favours owed) but its been dented both ends, probably squashed in a vice when having UJ's done and it vibrates but 80% less then the repaired staked prop.
Picked up a prop yesterday, good condition, circlipped UJ's £40 bargian, approx 1 inch longer than mine and a different size spline sliding over the gearbox output shaft.......sheesh.
Luckily the Piaggio Porter is a second vehicle so going to locate another prop.
ldv.tek
Post by HighlyJetted on Sat May 24, 2014 10:08 pm
It was a nice idea though, and a fair bit of work went into it.
The accuracy required to stop the UJ's from excessively wearing is quite high, and then there's the balancing which will be upset with the washers and welds.
I have a couple of cir clipped prop shafts which have a buggered UJ. They are 1.3 van ones.
So if you want one to rebuild we could organise something.
At least just swapping UJ's is pretty straight forwards as long as you keep the shaft aligned as it came apart with some marks.
Post by d1noh on Sat May 24, 2014 10:59 pm
I just payed £65 for 2 new uj's, not sure if thats cheap or not
