Daisy problems!! advice plz
Post by Poppi on Wed May 21, 2014 1:31 am
Poor daisy had to have RAC out he thought it could be condenser or points problem as she wouldnt start and back fired but have looked at engine number and she is a CB 42 engine which is i believe an EFI and so i dont think she has points and condenser? so could it be rotor arm problem? or any ideas please?????
Poppi
http://www.poppisupholstery.co.uk
Re: Daisy problems!! advice plz
Post by Logi on Wed May 21, 2014 6:59 am
Yeah, don't get that RAC man out again, he's a dick. There's no rotor arm on the 1.3 either. What age is yours? You need an OBD reader if it's new enough or look up reading the flash codes on here.
Post by Poppi on Wed May 21, 2014 7:30 pm
Hi Logi mine is a 993cc 1994.
Got home on RAC towing bar (scary) topped up petrol went out and she started sweet as a nut this morning so i'm guessing i need a new petrol guage lol as she was reading half full  Rolling Eyes
Poppi
Post by HighlyJetted on Wed May 21, 2014 8:18 pm
993cc does have a rotor arm and cap.
Do you know if you have an engine warning light that works on the dashboard yet?
Post by Logi on Wed May 21, 2014 10:34 pm
Need to get a bigger screen on my phone, coulda swore that was the newer style cab  Embarassed
Post by HighlyJetted on Wed May 21, 2014 11:25 pm
CB42 has that crappy dizzy setup with the weird curved toothed gearbox underneath which is a bitch to get timed up right if you take it all apart. Don't get me wrong it doable - but you have to do a bit of thinking trying to work out which way to move the toothed/gears if you run out of adjustment.... then you go the wrong way and get even more confused!!
There must be a proper way to do it but I've never bothered to read the 993cc engine manual Sad
Post by Poppi on Thu May 22, 2014 4:12 pm
Ok Update starting ok but not running perfectly and as my only vehicle she has to be reliable.
Son fitting new dizzy and rotor arm tomorrow and might still need a new petrol gauge. And to top it all one bolt head snapped off on removal; Oh the joys of an older vehicle (I was an Imp club member before and still have a project husky)
Poppi
Post by PFM on Thu May 22, 2014 9:33 pm
Husky? Wow, bet they're even harder to get bits for than a 'jet!. Cheap petrol guage is a piece of paper on which you write the mileage when you fill up - then add 150 and fill up again when you get to that mileage. (Doesn't work if the paper blows out of van when you open door, though!)
Post by HighlyJetted on Thu May 22, 2014 9:39 pm
Are you just ignoring my engine warning light questions?
And your just going to change the dizzy cap with no knowledge if that is actually the problem?
Before you buy a new one visually inspect the insides of the cap and arm, it might be sweet.
If your warning light actually works then we can do the paperclip test and see if its trigged any fault codes, which may point you in the direction of the fault.
Post by Poppi on Thu May 22, 2014 11:32 pm
PFM husky part easy to get as i know where to get them lol And the mileage idea is what i've just done  Very Happy
Highly jetted not ignoring lights but all ok there come on as should do and straight off on starting.
My son knows what he is doing and yes the dizzy and arm do need replacing.  Sad
Poppi
Post by HighlyJetted on Thu May 22, 2014 11:42 pm
So have you paperclip tested it for error codes?
Post by Poppi on Thu May 22, 2014 11:44 pm
I don't know about a paper clip test or how to do it !
Poppi
Post by HighlyJetted on Thu May 22, 2014 11:56 pm
Post by Poppi on Fri May 23, 2014 12:08 am
Cool Thank you Highly jetted will get son onto that asap.
Poppi
