Air Filter
Air Filter
Post by difflock123 on Tue Aug 24, 2010 2:21 pm
Hello people...
I cant seem to get air filters for the hijet locally, and besides, the airbox is about knackered.
I have fitted a conical airfilter to the van...
It sits under the drivers seat where the airbox used to...
Been round the block, and wow, what a difference it has made.
The only think I wanted to ask, is what is the small tube that runs to the airbox?
It runs from the airbox to a small unit at the front under the seat, with 3 other hoses off it, and a couple of wires...
What is the unit?
Thanks,
Re: Air Filter
Post by rich the mechanic on Tue Aug 24, 2010 3:06 pm
I believe that that is the air speed/flow meter or air pressure meter it sits on the atmospheric side of the filter so as long as you cable tie the pipe up nearby then it should be okay
Re: Air Filter
Post by difflock123 on Wed Aug 25, 2010 8:13 pm
Fair enough.
Currently its just wrapped around itself....
I was shocked at the extra power the engine seems to have developed mind you Very Happy
Re: Air Filter
Post by kentgpz11 on Wed Aug 25, 2010 8:51 pm
I was pleasantly surprised at the extra power I unleashed when I fitted a motorbike silencer to our van,
after the original one rotted & fell off. Cool
kentgpz11
Re: Air Filter
Post by difflock123 on Thu Aug 26, 2010 8:39 pm
It seems the hijet is quite restricted really....
the tiny airfilter pipes, the completely un-gasflowed airbox, and the stock silencer...
The airfilter I fitted made the performance increase dramatically Very Happy
Will break traction in 1st on a dry road, with 400kg in the back Very Happy
Re: Air Filter
Post by large519 on Sat May 07, 2011 12:12 am
[quote="difflock123"]Hello people...
Which type of aftermarket filter did you fit??/ K&N style?? Did you have to use reducers to fit it to the intake??
large519
Re: Air Filter
Post by difflock123 on Sat May 07, 2011 10:46 am
large519 wrote:Which type of aftermarket filter did you fit??/ K&N style?? Did you have to use reducers to fit it to the intake??
Yes, a cheap K&N copy (cost £20 with all the adaptors I think)
basically, I just used one of the small reducers supplied with it, and it all fitted nicely.
It does increase the induction roar quite a lot though....
what silencer
Post by stan lawson on Fri Jul 15, 2011 4:43 pm
Hi what silencer did you use as mine is us and having a hard time finding replacment
stan lawson
Re: Air Filter
Post by difflock123 on Fri Jul 15, 2011 7:54 pm
as far as I know, its a very common motorbike sports/race can.
you can pick them up on ebay at times for £10~£30 without the 'link pipe'
being stainless steel, they dont really rust either Smile
Re: Air Filter
Post by kentgpz11 on Sat Jul 16, 2011 4:48 am
I used a Kawasaki GPX250 silencer, only because that's what I found in my garage & the link pipe diameter was about the same.
Unfortunately it wasn't stainless steel, so it rusted & fell apart. Laughing
kentgpz11
cone filter
Post by stan lawson on Thu Jul 21, 2011 2:59 pm
Hi just stuck a cone filter on my van used a bit of pipe to get it to fit and then ran it for half hour idle no overheating and in this time the temp gauge only went up about a quater hope this is a good as its looking
stan lawson
Re: Air Filter
Post by difflock123 on Thu Jul 21, 2011 3:26 pm
Mine ran cooler with the cone filter....
Re: Air Filter
Post by difflock123 on Mon Jul 25, 2011 9:42 am
They will work fine.
It wont turn the Hijet into a sports car beater, but it will improve its responsiveness a little.
the standard air intake system is quite restrictive.
Re: Air Filter
Post by leopard_pagan on Mon Jul 25, 2011 9:48 pm
hmmmmmmmmmmm *rubs chin*..........
Re: Air Filter
