I lost it.....
I lost it.....
Post by rich the mechanic on Tue May 27, 2014 10:04 pm
..... so I have made a new one all baffled as it should be
Re: I lost it.....
Post by HighlyJetted on Tue May 27, 2014 10:29 pm
Hmmm.... but what is it?
Brake fluid pot?
Re: I lost it.....
Post by PFM on Thu May 29, 2014 7:40 pm
LPG tank?
Re: I lost it.....
Post by Logi on Thu May 29, 2014 8:32 pm
A vice? Wink
Re: I lost it.....
Post by FrontBackSide2Side on Thu May 29, 2014 8:56 pm
I think you've got us all baffled Laughing
Re: I lost it.....
Post by skybo on Thu May 29, 2014 9:10 pm
is it something fuel related? cap? return.. cant wait to find out
skybo
Re: I lost it.....
Post by rich the mechanic on Thu May 29, 2014 10:16 pm
Re: I lost it.....
Post by FrontBackSide2Side on Thu May 29, 2014 10:47 pm
i'm non the wiser Laughing
Re: I lost it.....
Post by HighlyJetted on Thu May 29, 2014 11:13 pm
Pimp!!!
Re: I lost it.....
Post by Guest on Thu May 29, 2014 11:51 pm
Filler cap / engine breather/ moisture separator to stop oil mist going into the manifold. Presumably engine is pretty worn and Gasses getting past the piston and pressurising the crankcase and rocker cover and blowing the plastic one out of the filler hole.
Re: I lost it.....
Post by rich the mechanic on Fri May 30, 2014 11:11 pm
woody wrote:Filler cap / engine breather/ moisture separator to stop oil mist going into the manifold. Presumably engine is pretty worn and Gasses getting past the piston and pressurising the crankcase and rocker cover and blowing the plastic one out of the filler hole.
Or I left it hanging on the pipe and it fell off  Embarassed
And HJ it's only pimped when polished and plated.
Re: I lost it.....
Post by Guest on Fri May 30, 2014 11:14 pm
Whichever, its OOPS .
Re: I lost it.....
Post by skybo on Sat May 31, 2014 10:47 am
did you look for plastic one in exhaust heat shield. lush job man
skybo
Re: I lost it.....
Post by rich the mechanic on Wed Jun 04, 2014 10:15 pm
skybo wrote:did you look for plastic one in exhaust heat shield. lush job man
No what heat shield? And thanks  Smile
Re: I lost it.....
Post by skybo on Tue Jun 10, 2014 7:45 pm
maybe it was removed. mind you I have a 3 cylinder engine. it between manifold and engine
skybo
Re: I lost it.....
Post by rich the mechanic on Fri Jun 13, 2014 9:19 pm
skybo wrote:maybe it was removed. mind you I have a 3 cylinder engine. it between manifold and engine
Do you mean the one under the spark plugs? if so then no it's well gone.
Re: I lost it.....
Post by skybo on Fri Jun 13, 2014 9:29 pm
that's the one, was it a 3 cylinder then? I remember looking for the source of a oil leak witch turned out to be distro (dizzy). your a wizard on the lathe mate
skybo
Re: I lost it.....
