Carpet questions
Carpet questions
Post by FrontBackSide2Side on Fri May 30, 2014 5:01 pm
Are the carpets from the vans the same as in the pickups?
Also, are they all the same colour? mine are grey and was wondering if you can get them in black?
Re: Carpet questions
Post by d1noh on Fri May 30, 2014 6:42 pm
I have used a Van carpet in a pick up, still Grey the one I had
Post by FrontBackSide2Side on Fri May 30, 2014 6:59 pm
Cheers bud, did it fit perfectly?
Post by d1noh on Fri May 30, 2014 7:14 pm
no problem at all
Post by PFM on Fri May 30, 2014 9:50 pm
Cab in vans and pick-ups is the same AFAIK so carpets should fit. I've used local carpet shops for off-cuts in the past - well cheap, but old shop dust-mats last longer.
