hijet suddenly no power..
Post by scotia on Mon Jun 16, 2014 10:06 am
hi ive got a 2000 1,3 16v van.
this weekend when driving on the highway i suddenly had no power and had to redirect myself on the emeregencylane.
when i shut it of and started it again it was just fine...?
this is the second time it happened and its verry dangerous situation when there is no emergencylane  pale
symptoms
-it happened when i was driving calmly behind a truck, i didnt shift or do anything when it happend.. i was just following a truck and driving 90kmp.
-all elecktrik works and i can press the gaspedal and hear it roar but nothing happens.
-i tried to shift back and press the shiftpedal o couple of times while redirecting to the emergencylane ... didnt help.
i hope you guys can help
Re: hijet suddenly no power..
Post by HighlyJetted on Mon Jun 16, 2014 8:39 pm
A common cause of this is a faulty vehicle speed sensor on these hijets, you'll be cruising along then it looses all its power, still runs, will rev up, just hasn't got the power to make it drive! Vehicle speed sensor is in the clocks.
On a different van, I had a similar issue, which I thought was the vehicle speed sensor, but it was actually the fuel pressure regulator sticking.
Post by scotia on Tue Jun 17, 2014 7:57 am
ok thanx for your reply.
so i have to replace the clocks?
you mean the hole dashboard unit or can i just replace the sensor?
i have driven my hijet without a speedocable since i had it
i dont know if that has something to do with it..?
Post by HighlyJetted on Tue Jun 17, 2014 8:37 am
As you will probably know all Daihatsu VSS work the same.
Gearbox drives a speedo cable,
Speedo cable drives the clocks,
inside the clocks there is a magnetic reed switch, which when the cable spins a magnet forces the reed switch to open even rotation.
This reed switch then connects to the ECU.
Reed switch/VSS is a non replaceable part of the clocks.
So fix your speedo cable for a start.
Post by scotia on Tue Jun 17, 2014 3:45 pm
i did the fault code reading thingy..
it was indeed the code 52 – Vehicle speed sensor signal – open or shorted
thanx for the help en the other info you put on here
realy awsome  cheers
i will post here when i fixed it
Post by scotia on Sun Jul 06, 2014 10:47 am
seeing how its fixed to the gearbox and then the angle it goes to the front of the van.
its not verry wierd that its going to break at some point in time.
the cable itself is just about the length it needs so it always under tension this way.
i replaced the cable yesterday.
the faultcode is gone now and it hasnt shut down while driving till now.
so i think its fixed  Smile
i replaced the dashboard lights to because it was out already.
i drilled out the 3 green bulb covers and put some white leds in them.
lookes much better and you can actually see something now.
the old lights were extremly dirty and black and the green covers didnt look any better.
verry happy now
thanx for the info+help  What a Face
Post by HighlyJetted on Sun Jul 06, 2014 8:25 pm
Great news Smile
Post by FrontBackSide2Side on Sun Jul 06, 2014 9:40 pm
Nice one. Can I see a pic of your clocks with the lights on please? Smile
Post by Nippy lippy on Thu Sep 11, 2014 4:18 pm
What about same scenario but engine cuts out compleatly. Cruise to hard shoulder and she restarts via a jump as I'm cruising to a stop! Cooling system is fine but fuel filter is poss the original! 2000 1300 pickup!
Nippy lippy
