extended wheel studs
Post by FrontBackSide2Side on Sun Jun 22, 2014 11:40 am
Does anyone know the specs for the extended wheel studs used on the rear when fitting alloy wheels?
I'm after the size of the spline and length etc?
Re: extended wheel studs
Post by HighlyJetted on Sun Jun 22, 2014 12:08 pm
Why do you need them?
What wheels are you fitting?
Post by FrontBackSide2Side on Sun Jun 22, 2014 8:10 pm
I'm fitting some starmags and I can only turn the nuts about 4 full turns before they are tight. Fronts are alright.
