not idling
not idling
Post by Timosaki on Sat Jul 19, 2014 12:47 pm
Problems right on the day i picked up the porter 1.3efi.
Started it where i bought it, no problems.
After a 65km drive at about 90 to 100km. When i got off the motorway, it stalled when i pressed the clutch. And after that, it stalled everytime i let the gaspedal go...
Also, the exhaust sounds like theres a leak somewhere. Wasn't like that when i left either.
I haven't checked it out yet with this heat, but do any of you know if it could have to do with the heat? Something lke vapourlock or such
Timosaki
Re: not idling
Post by Timosaki on Sat Jul 19, 2014 5:00 pm
Had a look just now. The leak is the gasket between the exhaust manifold and cat. Just beside the lambda sensor on the manifold. Could a leak like this influence the lambda sensor?
Timosaki
Re: not idling
Post by scotia on Sun Jul 20, 2014 10:03 am
i have driven mine without the last exhaust and it still runs..
im no mechanic but thats not the result of a missing exhaust gasket.
did it overheat or do you have a light that comes on? motorstoringslampje?
Re: not idling
Post by Timosaki on Sun Jul 20, 2014 12:43 pm
No, cooling worked pretty well on the motorway. Even at 30+ °C. It has just gotten a new temp sensor and clutch.
No motor management light either.
But, it works fine when cold. Well apart from the rumbly exhaust.
Timosaki
Re: not idling
Post by Timosaki on Sun Jul 20, 2014 12:45 pm
And this leak is right after the Lambda sensor. So i thought it might have something to do with it.
I don't know if i can adjust the idling speed of an efi myself...
Timosaki
Re: not idling
Post by HighlyJetted on Sun Jul 20, 2014 8:37 pm
I would also concider testing the TPS sensor and the MAP sensor.
If you unplug the lambda sensor does it still idle bad?
Does the efi light work on the dashboard when you turn the key on?
Re: not idling
