heeeellllllppppppp lol
Post by 88jumbo on Fri Jul 25, 2014 9:16 pm
hey there and thank you in advance!!
i need some help!! i was driving my 88 hijet jumbo with the 550cc 4spd after washing the motor down and it was running fine all the sudden was like it droped a cylinder and she started to spit and sputter and died tried to start it a few times to no avail Sad changed the plugs and nothing still.
i have ngk bpr6es plugs in it thats what had crossed over to it.
i am alslo looking for any and all info i can get on the 550 motor in the unit along with cross over parts like air filter etc
88jumbo
Re: heeeellllllppppppp lol
Post by 88jumbo on Sat Jul 26, 2014 4:18 am
so an update i did a compression check today its 150psi ish give or take 5 across the 3 cyl but it seem so have a weak spark. pleanty fuel as well. any ideas?
88jumbo
Post by HighlyJetted on Sat Jul 26, 2014 9:50 am
I'm guessing its an EB engine it your hijet.
I would probably go in both directions:-
I would remove the dizzy cap and lead - clean everything up, and if possible try to find another set of leads that you can bodge on from something. Leads are a common issue on old hijets.
I would strip and clean the carb, as on a 26 year old vehicle its just routine maintainance - make sure all the jets are 100% clean.
Post by FrontBackSide2Side on Sat Jul 26, 2014 10:33 am
I'm going to guess you have water in the dizzy.
Post by 88jumbo on Tue Jul 29, 2014 3:22 pm
no water in the cap changed the leads and plugs and nothing
im no good with carbs at all. and not sure of the engince code all i know its the 5500 cc new generation it says on my tailgate.
does the disturber have points? and on top of the coil pack there is a bar with wires on it are thay known to go bad?
88jumbo
Post by HighlyJetted on Tue Jul 29, 2014 3:35 pm
Post up some photos of your ignition system.
