starter motor
starter motor
Post by singledad on Mon Aug 04, 2014 10:47 am
hi all, think im going to be needing a starter motor for my 1999 t reg 1.3efi soon any about ?(woody) lol,and what sort of price
singledad
Re: starter motor
Post by singledad on Wed Aug 06, 2014 10:02 am
does anyone know if you can still get new brushes ?
singledad
Starter Motor
Post by rajrakhiria on Mon Nov 10, 2014 9:57 pm
Did you manage to sort one? It's probably a struggle to find a decent one at a guess?
I think my original one in my 1998 S Reg is on its way out.
May consider re-condition also.
Regards
Raj
rajrakhiria
Re: starter motor
Post by HighlyJetted on Mon Nov 10, 2014 10:55 pm
Take it apart first and clean the comms and contacts.
Re: starter motor
Post by scotia on Tue Nov 11, 2014 7:27 am
last week i took mine to the shop to get refurbished.
cost me 50 euros.
a second hand one would cost me at least 35 euros
and how long will that last..
i would contact a few shops to see what it costs to refurbish it
i was supprised how cheap it was cheers
Re: starter motor
Post by HighlyJetted on Tue Nov 11, 2014 8:16 am
I bet for 50 euros, all they did was unbolt the sleeve, slip out the winding shaft, clean up the commutator, blow out all the filth, lube up the bearings, put that lot back together - then cleaned up the starter solenoid contactors.
If you give them one that still sort of works, life is pretty easy.
But if you give them one with burnt out windings or a burned solenoid then it becomes a bigger job.
Re: starter motor
Post by scotia on Tue Nov 11, 2014 8:46 am
it still worked.
but just not all the time
he talked about replacing the worn bits/parts.... so i dont think so higlyjetted
i got warrenty on it and all.
i will contact the shop and will let you know what they did excactly.
Re: starter motor
Post by singledad on Tue Nov 11, 2014 2:15 pm
stripped and cleaned mine its been ok most of the time since but its brushes are worn so need to track some down soon
singledad
Re: starter motor
Post by HighlyJetted on Tue Nov 11, 2014 7:10 pm
If I need brushes for a motor, I simply measure them, then hunt for something as close as possible on ebay, then sand paper them down to size to fit. http://www.ebay.co.uk/sch/i.html?_from=R40%7CR40%7CR40&_sacat=0&_nkw=carbon+brushes+starter&_sop=16
Re: starter motor
Post by scotia on Tue Nov 18, 2014 7:14 am
he opened it up.
cleaned and lubed up some parts.
and machined something ..?
i asked him why he did this
because i left it there to be refurbished not cleaned.
he told me that that the inside parts were fine and didnt need replacing.
and if it fails in the comming time i can take it back to them.
so yeah you were wright hj  Embarassed
i then put the startermotor+a new battery back in the hijet and geuss what
it started like a new car  cheers
Re: starter motor
Post by Eightpot on Tue Nov 18, 2014 6:16 pm
scotia wrote:he opened it up.
Probably turned down the commutator to clean up where the brushes contact.
Eightpot
Re: starter motor
