high jet brake pad fitting pins
Post by sammillimob on Thu Aug 07, 2014 10:52 pm
Really need to purchase some fitting pins for front brake pads. High jet 2000 1.3 efi
cant find any.....please if anyone knows where I can get some get in touch many thanks
sammillimob
Re: high jet brake pad fitting pins
Post by scotia on Fri Aug 08, 2014 7:48 am
ask the guy in this topic, he seems to be looking for the same part.
second post from the bottom
http://hijet.findtalk.biz/t2382-wanted-brake-pad-springs-fitting-kit-for-drivers-side-96-se
Post by sammillimob on Fri Aug 08, 2014 11:56 am
scotia wrote:ask the guy in this topic, he seems to be looking for the same part.
thanks I have tried the link to big red but they are updating that section!!typical, will keep looking
sammillimob
Post by d1noh on Fri Aug 08, 2014 6:41 pm
Why do you require new pins?
Post by Guest on Fri Aug 08, 2014 8:23 pm
If you have the original ones and they are straight but rusty then put them in a battery drill chuck and spin them up and sandpaper them smooth.
If you haven't got them give me a call and I will stick a set in the Post for you
07863030309 or hi.jetmaniow@gmail.com
Post by FrontBackSide2Side on Fri Aug 08, 2014 9:34 pm
try ringing them or email Smile
