engine will not turn over hmmmm
Post by dec51 on Fri Aug 08, 2014 2:28 pm
ermm engine will not turn over ..
the starter motor is flicking in and out tho ..confused.com any thoughts ??
thinking of rotating the engine by hand /socket/spanner but its been so long since i had to do this i have forgot how advise if u can pls .. one of my worry's is is this engine seized  Rolling Eyes
.. or large f***ing hammer lololol
dec51
Re: engine will not turn over hmmmm
Post by d1noh on Fri Aug 08, 2014 6:43 pm
did you test it back on the truck?
Post by FrontBackSide2Side on Fri Aug 08, 2014 9:31 pm
classic sign of not enough power reaching the starter motor. Have you checked the 2 thinner wires coming from the positive battery terminal?
Post by dec51 on Sun Aug 10, 2014 6:59 pm
Shocked  well the engine was seized. after spraying wd40 into and onto every cog plug hole and almost everything else the engine is now free,, i'll put the spark plugs back in tomorrow (if the weather is ok  lol) and see if it will fire up .. if you hear a loud bang and crunch it might be this way lolol... Very Happy
DEC
dec51
Post by HighlyJetted on Sun Aug 10, 2014 9:13 pm
How long has it been stood?
How long have you owned it?
What happened on the last time it ran?
Post by dec51 on Mon Aug 11, 2014 12:07 am
hi  HJ Very Happy
its been standing in a garage for 10 months
 i know the previous owner and bought it knowing there was a engine issue
basically it just stopped coming down a hill and could not get it restarted . ther was no loud engine noise no crunch it just stopped .and was put in a garage ,
the last time i know it was used was 10 months ago since then its sat in a garage
i have taken the sump off had a look up and it looks fine ,the cam belt is on .
2001 minibus  it has a piaggio engine in  ( no plugs in it at the moment)
DEC
dec51
Post by HighlyJetted on Mon Aug 11, 2014 8:32 am
Take the rocker cover off and see if the whole camshaft turns when you turn the crank pulley.
A fair few have snapped their cam shafts.
Post by dec51 on Tue Aug 12, 2014 11:55 am
thanks for that HJ ,did have a look and all is fine .. think there is piston ring issue now as theirs a squeak think from a piston ring since i put some wd40 down the pots , grr think this might just end up as a strip down
dec51
