I know it's been done to death - wheels
Post by Stuntman on Mon Aug 11, 2014 9:30 pm
Hello guys. Just a really quick question. I have been using search I promise
I'm after some alloys for my new mpv/ works truck. I have read that wobbly bolts and washers will allow a more common cps to be fitted. Is this true? And if so can you post a link to the right bolts on eBay please? I know it's a cheeky ask but I really want to get this project done in less that two weeks
Regards
Andi
Stuntman
Re: I know it's been done to death - wheels
Post by FrontBackSide2Side on Tue Aug 12, 2014 2:21 pm
It's kinda true but not ideal.
As there is no spigot on the back there is a bit of a safety issue with using wobble nuts, also some wheels will require longer studs on the rears and depending on the centre bore of the new wheels you will need to either modify the spigots on the front hub, have the centre bore of the wheel bored out or use spigot rings. Usually its a case of modifying the hubs/ boring the wheels out.
Post by Stuntman on Wed Aug 13, 2014 9:11 pm
Cool. Is there an idiots guide to wheels on the forum?
Stuntman
Post by FrontBackSide2Side on Thu Aug 14, 2014 2:23 pm
not that i've seen. Plenty of threads on here but all in different places lol
Post by Stuntman on Wed Aug 20, 2014 9:55 pm
Had both front hubs turned down, fitted 165/65/13 with a stretch
Stuntman
Post by jamesgates1000 on Wed Aug 20, 2014 10:33 pm
jamesgates1000
