Washer jet
Washer jet
Post by chinfuk on Wed Aug 13, 2014 9:40 am
Hi, does anybody have one of those washer Jets that sit on the outside of the van under the windscreen for sale please, my van has just failed an mot on it :-( is it necessary to remove the whole dash to replace it as I fear :-) Manny thanks, Ki
chinfuk
Re: Washer jet
Post by HighlyJetted on Wed Aug 13, 2014 9:33 pm
Sure is, as the clip is on the rear.
Unless you can fish the supply pipe out the hole, then bond the squirty jet in place.
Re: Washer jet
Post by rich the mechanic on Thu Aug 14, 2014 10:27 pm
You can get to the clip through the dash with the clocks out a pain to do but possible so long as you get the clip off and not the hose then pull out front swap and try not to brake your arm putting the clip back.
Re: Washer jet
Post by Guest on Fri Aug 15, 2014 4:38 pm
I can't get my mobile bear traps in there never not no how!
Re: Washer jet
Post by PFM on Fri Aug 15, 2014 5:41 pm
It's never bob-a-job week when you have something like that to do, is it?
Re: Washer jet
Post by Guest on Fri Aug 15, 2014 5:52 pm
I do the same as Matt. Stick the beggar on there with polyurethane sealant. To much hassle with that job otherwise.
Absolutely stupid design clipping it in from behind before putting the dashboard in, when all it needed was a twist and turn 45 degrees.
Re: Washer jet
Post by chinfuk on Fri Aug 22, 2014 11:37 pm
Thanks for all the replys,
I got it pass the mot with out changing it, the black plastic was intact but both the little metal nozzle things had gone, I found some necklace beads bigger than the hole, guessed at the direction and superglued them in place. That's it, they seem solid enough for now :-)
Anyway thanks again for the help, I love this site :-)
chinfuk
Re: Washer jet
Post by GEORDIE on Sat Aug 23, 2014 12:43 am
nice fix
GEORDIE
Re: Washer jet
